Share Your Device! - Advanced Virtual Devices from Device Capabilities
Chronograph timer/stopwatch/transition monitor and settable through Sliders (Update Oct. 6th '23)
This is an AVD with flow to view your timer/stopwatch/transition elapsed time / duration through SLIDERs, and if you like in a tile’s status field
Also you can SET the timer/transition duration with a separate SLIDER
Demo flow which comes with the AVD
Additional apps used:
Note
The slider’s MAX. value has to match the timer’s target duration value. Then the slider moves in a realistic way.
Also, the SET_Duration slider’s MAX. value should match the maximum duration (in seconds) you’d like for the timer.
(If I’m right the min/max/step/digits values aren´t settable through flows or scripts yet)
Demo with the web- and mobile app in one gif:
Peek 2023-10-06 05-36
AVD Settings:
When you have a timer with minutes as time unit, you can make the duration reflect minutes as well, by adding this BLL expression
$value/60/1000
(Dividing by 1000 is needed while the original value’s unit is ms)
A usecase: on a dashboard:
TEF:
[tef:AVD,FLOWS:"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":/tef]
