Can I create a flow based on the Wifi status to the Homey Unit?
My Homey seems to drop connection to WiFi a good bit resulting in me needing to unplug and plug the Homey Pro back in.
Is it possible to create a flow that if the Homey Pro loses WiFi that it will power cycle?
Yes. You can create an Advanced Flow. You should first add a When card, and choose “Every 15 minutes”. Connect it to a THEN card: Send HTTP request (from the Logic category). Enter https://connectivitycheck.gstatic.com/generate_204 as the URL. Add the Error point of that card to the “Reboot Homey” Then card
Thanks for the help. I am still pretty new with Homey so could I ask a few questions.
First off I am having hard time finding those cards. The Logic one I do not see a Send HTTP request and tried using the search. Then in regards to the reboot Homey could not find that either.
Finally what is that web address doing?
Thanks
This is an example:
How it works:
Every 15 minutes, it will send a web request to that URL. It’s a URL from Google that returns a 204 (no content) when you send a request to the /generate_204 endpoint. It’s the same service used by Android for internet connectivity checks. When the request fails, it reaches the error point. The request fails when the internet/network connection is offline, and then restarts Homey.
Also, if you want to check Homey’s connection to the Athom cloud servers, you can use this URL:
https://[cloudid].connect.athom.com/api/manager/system/ping?id=[cloudid]
You can find the Cloud ID in More→Settings→General.
Did you download any apps to get the Get HTTP and System Cards? I am not seeing those as an option.
No, they are available under the “Logic” category
Maybe you have to enable the Power User experiment in settings.
Edit: instead of this workaround you might just want to fix the issue instead. If homey isn’t connected, automations might not work as expected either.
There’s alot of information on this forum about similar issues.
Most likely it’s swapping between access points. In most cases you can “pin” the Homey to a specific access point in the networking software. Select the one it has the best connection with (most times, the one closest).
Thanks.
I enabled the power user and am still not seeing that setting.
I do use Google Mesh Wi-Fi so maybe that is the cause. I will look into the ‘pinning’
The cards should be there:
THEN → logic
THEN → system
Thanks!! I found it. I will try this out
The timeline card might not trigger, you should swap the 2 cards (Restart Homey and Timeline)
As Timeline cards can get subject to rate limits, I would connect it in parallel to the “restart” card.
Sorry…not sure I am following what you mean.
No problem.
This is what I meant with in parallel. Possibly it’s necessary to add a 1s delay to the “restart” card if the timeline notification doesn’t appear.
Because in series, like this, it can cause Homey to not get restarted in case of active timeline card rate limits: the card will fail
The timeline notification cards can get rate limited, due to too many notifications in a certain time frame sent from any of your flow.
There are no exact figures known (to me).
It can be resetted by time: after 24hrs, or by restarting Homey.
Gotcha. Thanks!
I think that’s my problem too. I’ll try this flow if it solves my problem.
Hi All!
Could you please help what I am doing wrong? My goal with an advanced flow is to restart homey first in case internet connection lost and if it does not solve the problem later switch off and switch on a zigbee plug to restart the router. I have created the following flow but I don’t know why it does not work. It is working until restarting homey but the plug is not switched off and on.
Could you please help me?
Thank you very much!
Regards,
Gábor
If Homey has restarted that does not mean that also all apps have been started. Most likely the Chronograph app has not yet started and the flow errors out.
To initiate a flow after all apps have started, you can use the corresponding flowcard from the sysInternals app (All enabled apps are running after Homey Restart):
The “10s” delay card disappears as soon Homey restarts / powered off!
The flow disappears as well without power :wink:
The zigbee outlet will never get turned on by Homey as long as it’s down.
My way:
I have it wait for a while to filter random network dropouts, or to filter these infamous Homey wifi / LAN faults.
The “Restart Homey” card works for me for the last 6y…
