Hello guys,
As you know, some devices can be directly connected to Homey through the Aqara-related app, and some devices connected to the Aqara hub can be brought into Homey via the Matter connection.
However, not all devices can be brought in, so I am forced to use Home Assistant together.
In Home Assistant, it’s possible to bring in all the sub-devices by using the method of connecting the Aqara hub to HomeKit. It would be great if there were an app in Homey that could bring in all devices in a similar way.
You mean the Homekit Controller app?
Hello robertklep, thank you for your interest!
I’ve tried to connect with Homekit controller app before.
When I tried to connect via Homekit controller, it shows many devices but I can’t control them.
Are you able to control the devices you brought in with the Homekit controller app?
If so, I’ll try again.
I don’t use that app (or Homey) but that’s the only app that is available to access devices through HomeKit. If it doesn’t work, you can ask for help in the app thread.
Thank you for your advise.
I’ll try it again and ask for help in the app thread.
