Hi, I’m running into a persistent “Timed out waiting for Waveshare response” and hope you can help pinpoint it.
Setup:
- Homey Pro 2026, wired Ethernet, IP 192.168.1.241
- Waveshare Modbus POE ETH Relay (8-channel), firmware V1.486, fixed IP 192.168.1.91, port 502, Modbus device ID 1, Work Mode TCP Server, “Modbus TCP to RTU” enabled, Multi-TCP Connection enabled
- Network: UniFi (UDM SE + US-24 switch), no VLAN separation; Homey reaches all my other local LAN devices without issue
What I have verified:
- From a Windows PC on the same subnet (192.168.1.232): Test-NetConnection 192.168.1.91 -Port 502 returns TcpTestSucceeded: True. Confirmed twice, with VirCom fully closed (also killed via Task Manager).
- Ping to 192.168.1.91 succeeds, 0% packet loss
- Board power-cycled several times (PoE unplugged 30s)
- App fully uninstalled and reinstalled; board re-added through Add Device → Waveshare Relay
- Tried polling interval 100 ms and 1000 ms, response timeout 750 ms and 2000 ms
Result: the PC connects to port 502 without any problem, but the Homey app keeps timing out. Live status shows “Last successful poll: never” with consecutive errors climbing. Board settings in the app are 192.168.1.91:502, Modbus ID 1.
Question: could there be something in how the app opens or frames the Modbus TCP session that this Waveshare model does not answer, even though a plain TCP connection to port 502 succeeds from another client on the same subnet? Happy to run any diagnostics or share a diagnostic report.
