Awning with 433mhz remote
I have an awning that has a remote that works on 433mhz. I’m trying to figure out how I can create a flow to open/close it with homey.
I’m not sure what the motor is but could check if I know what to look for. The awning has a sun and wind sensor.
The remote is a Go-sv, manual for remote is:
Any help appreciated!
433.42MHz is the same frequency as Somfy uses, try to connect as Somfy TRS.
I tried connecting a few times, but didn’t manage to…
I found:
Does homey support rolling code for rf?
The exact code for the brand needs to be in the app. This is not standardized between brands as 433.92 MHz is just a frequentie.
So you could try if it is the same signal and rolling code as another brand but there is not much chance.
You could try to make an app for it but then you also need to understand the rolling code.
Edit, Reading the pdf
433.92 is BTW the most common used frequency and only somfy I was aware of being just below that frequency on .42
Homey can use that also.
I guess not much chance other brands use 433.42.
I put the remote in pairing mode (button on back for 2 seconds) and the awning wiggles. I hit “program” in the app and it seems there is no wiggle, but the app progresses. I choose only up/down function as there is no tilt, but nothing happens with regards to the awning when pressing any buttons in the device on Homey.
I noticed in the dev tools that this remote shows a 0 under “rolling code”. I assume that means that rolling code is off?
Thanks for information. It is really amazing information you shared. I am looking for the same content.
Hi there, did you manage to make this work?
I have the same problem.
No unfortunately I haven’t found a solution yet for this.
Bumping my old thread but curious if anyone managed to get theirs working?
What could I look for of climb up to the motor of the awning? Might there be something there that could help better understand?
Pro 2023 models and up with latest firmware, now have a recently added “Clone 433MHz signal” tool.
You could try to learn and save the remote’s signal now.
I tried that but it wasn’t learning the signal. Said not found.
I have some Somfy curtains and I tried learning it in Somfy. It seems like it does pick up something when I push the setup button on the back of the remote but then the in/out don’t work. But it does recognize it
If it’s Somfy RTS protocol (not ‘io’) they might work when you add it with the Somfy RTS app installed?
The Brel app is another option to be able to learn a 433MHz remote’s signals.
The Somfy protocol uses a frequency that is not the same as most other remotes,
433.42 MHz versus 433.92 MHz, Homey can not receive both frequencies at the same time, for transmitting Somfy signals, it internally switch to the Somfy frequency.
