why? you think she is lying about the hours she makes??
You could also install locative on her iphone or some other app when its android. I think presence detection is a way to do this.
Just to pay her, she sometimes work one hour, other times more then 3 hours.
The presence part isn’t the problem, i need help with the Logic part
Perhaps use the count up timer…
Not sure if it is still available, but I do remember an experimental app that does countdown and count up. So, when present, start countup.
Great tip!!! Thanx.
Cheers!
Using Chronograph helps. Now i can make a few flows:
- when beacon in range, start stopwatch YYY
- when beacon out of range, stop stopwatch YYY
- when stopwatch YYY is stopped, calculate an value with Logic
Then i think i have to set a Numeric Variable… and then i get lost…
I can make a variable in More > Logic > New > Type should be Number probably, but what do i fill in at Value ?
You don’t need to calculate, juist read the stopwatch value. That is what you wanted!
The stopwatch time/value is in Seconds.
And i want to sent a message with the worked time (hours) in it. (So the calculation part must be something like Stopwatch value / 3600)
How would you solve this?
in the app settings of Logic you have to define a variable (hours) before
Flow:
when: stop watch stopped
then: based on the duration, Logic calculates seconds to hours
You post the options of the when area. But you have to select the options in the then area.
You are correct. Thanx. I got it working now. Thanx all !!!
Now a bonus question
How can I round this number to two decimal places?
{{round(dauer(s)/3600, 2)}}
I think to round a number you have to use the app „better logic“ instead of the bulidin Logic app
It works with the built in logic. No better Logic necessary.
@Osorkon you‘re right and I‘ve learned something
https://community.homey.app/t/available-math-functions/16622/3
It all works perfect, thanx for all the help!!! learned a lot.
