[APP] Aqara & Xiaomi Smart Home - A different kind of Smart Home solution (Zigbee App)
Hi there,
I have added some aqara devices to the new HP2023.
One of them have a problem :
Wireless Mini Switch (with Gyro)
There is no scene “action” selectable in flow
I can only use “a button has been pressed”
So strange too :
When I go to the device page, section “flow”
There is no flow associated, but I have a flow using this “a button has been pressed” when card
No problem with another type of button (mini Switch for example) : all scenes actions are available, and the flow appears in the flow page of the device
Thanks for your help
Do you mean this?
It’s selectable without problem for me …
Thanks Sharkys for your answer.
Verified today and : The actions are available !! :upside_down_face:
After the inclusion, there was no scene available. DOn’t understand why, but now it works :partying_face:
Any plans to add the “Aqara Scene Panel S1E Smart Switch Touch Control” (Product Model:CJPKGO1LM)?
Thank you for your time and effort! :slight_smile:
This seems to be a Wifi device. This app is focused on Zigbee.
You could try over here:
Is it possible to add the new GZCGQ11lm (aqara t1 light sensor 2023) to the aqara app on homey?
Thanks for a great app! Would it be possible to add “AND” command for Xiaomi Light Sensor GZCGQ01LM if “Luminance is greater/lower than xxx lx” ?
Total 8 routers via Aqara app. Multiple battery powered devices can be added. But suddenly I can’t add anything anymore. It searches for devices but finds nothing.
@TedTolboom can u look into this when u have time for it? v1.7.1 d9aeec16-b4a9-4873-8bbf-a6fd1ab91e92. With Homey Pro 2023 now 20 devices zigbee.
That’s a Homey firmware issue, not a Xiaomi app issue.
Is it possible to add Cube T1Pro as a device?
You need to use the logic cards for this:
Thanks, great! Need too learn the logic cards better :slight_smile:
Is it possible to add the Xiaomi Aqara “Radiator Thermostat E1” ( AQARA SRTS-A01) ?
Thanks a lot
@TedTolboom I have read your comments in different threads and i belive i havent got an answer to my question, this is also officially my first post. yeah!
I have Aqara Wall Switch H1 and the Aqara smart home app in Homey. The only flow cards for this device i get in WHEN are related to switching ON/OFF the switch. With these set of cards i get my hue lamp connected to the switch to get its POWER OFF when toggling the switch.
Instead, I would like to get a card of “WHEN Button is pressed”, then i can decide myself the upcoming actions, that would allow me to command a HUE lamp connected to the switch to go to a Off/ON/scene state and avoid gettting it powered off and get disconnected from Homey
Am i asking for too much? :smiley:
Thanks for the support!
Hello, I bought an Aqara Cube T1 pro and the app doesn’t recognize it… Is there any plans to add this device soon?
Thanks in advance
Martin
I see a lot of issues with the Aqara door/window sensor on the Pro 2023.
But it’s not clear to me if this is a homey firmware issue or an app issue. As other Aqara devices like waterdetector and rollershade driver do work without issues, it seems zigbee is working on the pro 2023.
A few days ago there was an update on the zigbee-stack but the doorsensor I added after that update also stopped working after about half an hour. (At about 2 meters from the Pro 2023)
So any idea what is causing the issues?
Eric
Devices unable to add or leaving Homey Pro (Early 2023) is a Homey pro software issue, since network management is handled by the Zigbee core (outside reach of this app).
Please report these issues to Athom, as instructed in the app based on your early access program.
When devices are added successfully, remain connected but are not functioning properly, please report these issues here.
This holds for all Zigbee or Z-wave based apps, not only for the Aqara app.
If devices stop reporting, please check if you’re using a powerful enough power supply and that the device still has a network address in the Zigbee overview at tools.developer.homey.app/zigbee
It is a known issue that certain Zigbee devices loose their network address. This was an issue at the early introduction of Zigbee on HP2019 and again has to be resolved by Athom on the HP2023…
I’ve got a lot of these door/window sensors on my homey 2023. They are all very stable now and working better then on my homey pro 2019.
What I did (after restore backup):
  1. First repair router zigbee devices beginning close of homey
  2. Repair the door/window sensors on the place you use them.
  3. They all give an error when repairing but if you trigger them multiple times, they work and stay working for a week now.
I ordered a new Aqara lux sensor as the previous became un-alive after working 2 years outdoor.
The new one is slightly thicker and is added as unknown ZigBee device.
"ids": {
    "modelid": "lumi.sen_ill.agl01",
    "manufacturername": "lumi"
  "endpoints": {
    "endpointdescriptors": [
        "endpointid": 1,
        "applicationprofileid": 260,
        "applicationdeviceid": 262,
        "applicationdeviceversion": 0,
        "_reserved1": 1,
        "inputclusters": [
          0,
          1024,
          3,
          1
        "outputclusters": [
          3
    "endpoints": {
      "1": {
        "clusters": {
          "basic": {
            "attributes": [
                "acl": [
                  "readable"
                "id": 0,
                "name": "zclversion",
                "value": 3
                "acl": [
                  "readable"
                "id": 1,
                "name": "appversion",
                "value": 27
                "acl": [
                  "readable"
                "id": 2,
                "name": "stackversion",
                "value": 2
                "acl": [
                  "readable"
                "id": 3,
                "name": "hwversion",
                "value": 1
                "acl": [
                  "readable"
                "id": 4,
                "name": "manufacturername",
                "value": "lumi"
                "acl": [
                  "readable"
                "id": 5,
                "name": "modelid",
                "value": "lumi.sen_ill.agl01"
                "acl": [
                  "readable"
                "id": 6,
                "name": "datecode"
                "acl": [
                  "readable"
                "id": 7,
                "name": "powersource",
                "value": "battery"
                "acl": [
                  "readable"
                "id": 8,
                "name": "appprofileversion",
                "value": 255
                "acl": [
                  "readable"
                "id": 9
                "acl": [
                  "readable"
                "id": 10
                "acl": [
                  "readable"
                "id": 11
                "acl": [
                  "readable"
                "id": 16384,
                "name": "swbuildid",
                "value": "2019"
                "acl": [
                  "readable"
                "id": 65533,
                "name": "clusterrevision",
                "value": 1
            "commandsgenerated": [],
            "commandsreceived": [
              "factoryreset"
          "illuminancemeasurement": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 0,
                "name": "measuredvalue",
                "value": 36967,
                "reportingconfiguration": {
                  "direction": "reported",
                  "attributedatatype": 33,
                  "mininterval": 3,
                  "maxinterval": 3600,
                  "minchange": 15,
                  "status": "success"
                "acl": [
                  "readable"
                "id": 1,
                "name": "minmeasuredvalue",
                "value": 1
                "acl": [
                  "readable"
                "id": 2,
                "name": "maxmeasuredvalue",
                "value": 50000
                "acl": [
                  "readable",
                  "reportable"
                "id": 3,
                "name": "tolerance",
                "value": 0,
                  "status": "unreportable_attribute",
                "acl": [
                  "readable"
                "id": 4,
                "name": "lightsensortype",
                "value": "cmos"
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
            "commandsreceived": []
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable"
                "id": 0
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              0
              0,
              1,
              64
          "powerconfiguration": {
            "attributes": [
                "acl": [
                  "readable",
                  "reportable"
                "id": 32,
                "name": "batteryvoltage",
                "value": 31
                "acl": [
                  "readable",
                  "writable"
                "id": 49,
                "name": "batterysize",
                "value": "cr2"
                "acl": [
                  "readable",
                  "writable"
                "id": 51,
                "name": "batteryquantity",
                "value": 1
                "acl": [
                  "readable",
                  "writable"
                "id": 52,
                "name": "batteryratedvoltage",
                "value": 30
                "acl": [
                  "readable",
                  "writable"
                "id": 53
                "acl": [
                  "readable",
                  "writable"
                "id": 54,
                "name": "batteryvoltageminthreshold",
                "value": 27
                "acl": [
                  "readable",
                  "reportable"
                "id": 62
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
        "bindings": {
          "identify": {
            "attributes": [
                "acl": [
                  "readable",
                  "writable"
                "id": 0
                "acl": [
                  "readable"
                "id": 65533,
                "value": 1
              0
              0,
              1,
              64
Yesterday I added the first 2 Zigbee devices (Aqara Vibration Sensor, lumi.vibration.aq1) to the HP23.
Vibration, Vibration Alarm, Tilt Alarm and Drop Alarm are working fine. However, the values of Tilt Angle and Relative Tilt Angle do not change. Both sensors still show the value 0 at both parameters.
Homey Pro 2023
Firmware v10.0.0-rc.65
Aqara App v1.7.1
Diagnostic Report No.: e61bb51a-a5b5-4ada-a142-f953b5097b67
Edit
App and Homey restart didn’t solved this problem.
@Fabian_Annequin, could you please format the code from the interview as code?
Thx!
