Aqara Presence Sensor FP1E
It’s a pretty bad article though:
“But for something like the Eve Weather that can track temperatures, humidity and barometric pressure to provide precise readings and even predictions, you want access to all of the features. But that isn’t what you get when viewing Eve through a Matter controller.”
And then it shows some bland screenshot from Google Home and compares it with a cool screenshot from the Eve app, showing nice charts and whatnot.
That just says that Google Home is junk. Other Matter controllers, like Homey or Home Assistant, have built-in functionality to create similar charts based on Matter sensor data.
Matter is, like Zigbee originally was, a greatest common denominator standard: it specifies the most common operations for each device type, and standardises those. It cannot possibly support all operations that you may think of without growing to a pig of a standard that nobody will be able to implement fully.
Dedicated apps for devices usually serve 2 purposes:
  • collecting user data (because for some reason you almost always have to register with some service)
  • device configuration
Device operation can usually be done using Matter just fine, because like I said, it supports the most common operations.
I have added the FP1e via Aqara M3 Hub.
It worked some hours and stopped updating this morning.
After restarting M3 hub and Homey it works again
I assume you connected it through Matter?
If so, issue a report request to Athom: https://support.homey.app/hc/en-us/articles/360015784034-Submitting-a-support-request
I have the same problem. The Aqara app is recognizing presence in a couple simple automations I made to test it.
But in Homey it has not activated a single flow since installing it.
I managed to get a webhook via IFTTT to kick off an automation in Homey but IFTTT only supports Presence yes or no so the functionality is limited. And I don’t like IFTTT as it is vslow and ery unreliable in my experience and not local activation.
I have a Linptech mmwave sensor arriving tomorrow so will see what it can do. $20 cheaper than Aqara.
Also the Hub E1 does not appear to support everything this sensor can do. Need to look into that more.
Same here.
The problem might also be on the aqara hub and sensor site.
The aqara hub didn’t recognize and transfer all the presence situations to sub systems.
This just in from Aqara…not very specific nor encouraging.
“Based on the Homey platform, we are currently optimizing the compatibility with its APP, so you may not be able to get a good user experience when using this APP for the time being; it’s recommended that you try our Aqara Home app (you can experience more existing private functions) / other third-party ecological platforms with relatively mature systems first; we will also speed up the improvement of this Homey platform and hoping to provide a better user experience in the future.”
Anyone else having a hard time keeping this sensor connected to Homey via matter. I works for a couple hours and then goes off line. Maybe I have a lemon?
Homey losing Matter connections seems to be a fairly common problem.
Did you get it to work?
No I did not. There are 2 apps that are supposed to work with it that you need to set it up with first, but neither would work. So I suspect it needs a different hub. I sent it back.
What i read isnt very positive. Is there already someone with a FP1E thats works directly to the HP23??
I have a couple of FP2’s but in some place i just want to detect people with mmwave
How would they do that…
The Aqara app doesn’t support it (yet)?
oh my bad, I thought some did get that work with work around or something.
maybe not a good idea to read this al in the nightshifts :rofl:
I found out the sensor is available as Matter device, when you first pair it with an Aqara hub (as zigbee device)
(Matter doesn’t need apps)
Compatible Hubs:
E1 = ~ €22 to €30
Hint:
The upcoming FP300 is Matter enabled on it’s own
I have successfully added FP1E to Homey Pro via Aqara Hub and app with Matter. Problem I see is like what is already discussed…motion alarm. I have a flow that uses luminance as a trigger within the flow, but have never been able to get this to work. If you are already in room, and lux is avove the threshold and then drops below while still in room, the lights/flow doesn’t finish.
Not really happy with how this integration is working and might just return it and go back to PIR sensors.
Especially with Nanoleaf products (shapes and elements) I have noticed lately. They seem to alway be dropped on a weekly bases
hello, how did you achieve to connect presence sensor FP1E to your homey pro? I have the camera G3 Hub from aqara, I have linked both on aqara app from ios, but I am not achieving to add the presence sensor FP1E to homey pro using matter or neither using homekit controller app.
Please help!
I have the same problem, I have linked on Aqara App from iOS, my hub camera G3 with my presence sensor FP1E, but I am not able to add presense sensor using matter or homekit controller app, due is not working…
You would need a seperate flow to turn on lights when lux falls below treshold, as your flow only turns on lights when motion is detected AND you are home AND lux is below treshold.
I bought an Aqara E1 hub on your recommendation. Installed it on the Aquara APP and also linked both my detection sensors FP1 to the App.
Then with Matter linked the HUB E1 to the Homey Pro, which worked.
Why can’t I link both FP1 sensors to the Homey via Matter ?
Do you have another tip for me ?
