Aqara FP1E
Having trouble having my Homey Pro to recognize my Aqara FP1E, my FP2’s I have installed work great, its just this one aqara product….
Andy Bell
Sorry, I can’t help because I can’t even get my FP2 to connect?
How on earth did you do that?
/Per
Via Home Assistant…. I connected to Aqara app then HA then used Home Assistant app on Homey Pro and everything came over connected EXCEPT FP1E…. ugh… I know it may be a “Aqara” thing, but not entirely sure…
Does FP2 use WiFi? You can maybe use IFTTT to integrate it with Homey.
Yea, FP2’s are fine (connected) it’s just the FP1E that is having issues.. maybe the upcoming “update” will rectify the issue (and thank you for response)
Andy Bell
Do you have an Aqara hub? Then you might be able to connect the FP1E via IFTTT as well.
With this app:
(note: you don’t need any apple devices)
It should work, according to the Aqara topic. Maybe you bought a Chinese Mainland version? Because that won’t work!
The sensor should have this model description:
lumi.sensor_occupy.agl1.
Otherwise please use the the app topic for Aqara related issues:
I have Aqara FP1E paired directly to Homey pro without any issues, working normally. I’m using Aqara app what Peter Kawa linked above.
I’m also having a problem with the FP1E in Homey. While it works fine in the standalone Aqara app, when I delete it in the Aqara app and add it in Homey using the Aqara app it either gets stuck in presence detected or absence
Hi Frank,
