Aqara flow with timer
I got a Aqara sensor on my window in the bedroom. I would like to make a flow where when the sensor has been active in 15 min. I will get a notification on my phone. Is it possible when there is no timer app on the bridge ?
I don’t own a bridge, but that should work.
Flow 1
If…
– Contact alarm turned on
Then…
– Start Flow 2 with a delay of 15 min.
Flow 2
If…
– This Flow was started
And…
– Contact alarm is on
Then…
– Push notification
R U sure?
Try before you ask.
I use an extra variable; tested and works:
Although you shouldn’t close and reopen the window within those 15 minutes, otherwise you get a cascade of flows that get started.
“no timer app on the bridge”
…or try yourself before you advising others to try … :slight_smile:
Done, many times! Thanks for this advise.
That’s right. :+1:t3:
Sorry @Jan_Peeters, but as I read your first post my reaction was the same like @JPe4619. I wrote “that should work”, not “that will work”. And you ask me if I’m sure??? After that, you post flows with a timer app which is definitely not available on the bridge… :man_shrugging:t3:
The reason why I wrote “that should work” was, because I don’t own a bridge and I don’t know exactly if there is a “Delay” option with the bridge.
You don’t need a Bridge to test Homey (beta). Only you can’t add fe virtual KAKU devices to test. Keep it with the standard actions.
Perfect dear sir, thank you very much. That did the job :grin:
