Aqara Dual relay module T2
I installed an Aqara Dual Relay module T2. Couppled with Home Pro.
You can uncouple the inputs from the outputs so you can give the inputs other use then
switching the internal relais.
This works fine voor SW1, but does not for switch 2.
I changed the device for a second one, no result.
Changed SW1 and SW2 hardware side (wire’s) and in flow no result.
Suggestions ?
Kind regards, Dirk
