Aqara T2 double switch
Hi, i integrated 2 Aqara T2 Relais. Both Module are switching the output Channel off and on every 20 seconds. Interlockmodus is off and i have no flow configured. What is wrong with the modules or configuration?
The Support of aqara is Meaning they are a timer configured but this is only a function of aqara hub.
Has somewhere else this issue?
Best regards
Yes, have same problem, only it is switched on/off once every minute. Two relays on the same hub. If homey is offline, the problem stops. Did you find a solution?
Hi, sorry, i have no results. I wrote with Aqara Support. They give only Support to Aqara Hubs.
Answer from Aqara:
The Dual Relay Module T2 is designed to work with Zigbee protocol and supports HomeKit integration. Since you’re using Homey Pro without an Aqara hub, the behavior might be related to how the modules communicate with the third-party platform.
​Currently, the official supported way to connect to Homey is via Matter over Bridge. First, bind your devices to the gateway in the Aqara app. Next, go to the hub settings, select third-party Matter system to generate a new Matter code, then scan the code with Homey to add the devices. This method requires you to own both an Aqara hub and a Homey hub.
So, i dont no what i am doing. I dont want another hub.
It seems to be a bug on the zigbee network introduced by the latest homey update. There is a New experimental fix out. Install it or wait for full update :ok_hand:
