hi, can anyone when apple homekit will work. I just problem it says it does not work. Brian
Works for me. I use Siri a lot.
Hi welcome to the community,
For all your questions pls read Trouble with Homey? first. Then search the community and edit your post to add required info.
Iām still on Homey 4.2. I have been using Homey with the HomyKit app for around 6 months now. Iāve never been able to get it to work reliablyā¦
Homey regularly losses network connection to all of my Apple devices. Mostly when my phone or IPad have gone into standby mode but also randomly happens while Iām actually using them.
Quite often my Apple devices say they canāt connect. If im lucky and I wait 30 seconds and then try again it works⦠Im almost guaranteed to lose connection to Homey (via HomeKit) when Iām away from my home and my phone is connected to 4G LTEā¦
My iPad Pro is acting as the HomeKit hub in my house. The phone i use is an iPhone XR⦠All are on the latest apple updatesā¦
Does anyone else here have issues using Homey with Apple HomeKit ?
When I was still using Homey for Homekit, I had similar issues. It was never really stable. I blame Homeyās networking.
Never any problems as such here. ATV is the hub
I might try an Apple TV or HomePod as a hub instead and see how that goes.
Rob, what do you think the cause is exactly ? Is it something that Athom canāt fix in their code. Are there any work aroundās. ?
Do Athom really care about HomeKit ? After all this time they still have it buried in the experiment section and havenāt formally made it apart of the system. Have they made any effort to find or encourage another developer to get it up to 100% working . There are many IOS users out thereā¦
The ironic thing i find is that Homey ās look and user interface is very much styled off HomeKit yet they donāt seem to care about it from what I can seeā¦
I donāt know why Homey can be so unstable when it comes to networking. For some people it works fine, others have lots of issues. Itās not related to a particular app, because other apps also suffer from the same problem. The issue seems to be related to maintaining long-running connections (like for Homekit, or things like websockets).
As for Athomās own Homekit implementation: I donāt know why it even exists anymore. I donāt think they work on it, it was implemented as part of a āhacky fridayā if I remember correctly, and itās quite limited. I guess Athom just wants to be able to tell prospective buyers that āHomey supports Homekitā.
Hereās an update to my situation ā¦
I just purchased a new HomePod Mini today and hooked it up to my home network.
I removed my IPad as being the Home Kit Hub in my network⦠That is what I was originally using for all my IOS devices to join to.
I removed and deleted all the settings in the HomeyKit app .
I removed Homey as being a bridge in my IOS devices.
I rebooted Homey and paired my new HomePod mini to Homey. It didnāt pair the first time, but paired on the second attempt.
I then rebooted Homey again just to be safeā¦
Since then Iāve been testing everything for about 3 hours now.
So far so good.
Everything seems to respond fast and quick and is fairly snappy ⦠Iāve havenāt had any failures to connect my devices at all.
While Iāve been testing everything tonight I also turned off the Wifi connection on my iPhone so itās just connected to 4G LTE. (As if I was away from home)⦠It also hasnāt had any failures which previously happened a lot while I was away from homeā¦
Iāll post an update tomorrow on how my testing ultimately goes but so far so good⦠My iPad was probably the contributing factor to my issues but it sounds like Homey needs to get its code up to scratch.
If it starts to work reliably from now on Iāll be happy but I will still have some very stern comments to make about Athom.
Their business model and attitude are totally deplorable. This is shared by many comments Iāve seen over the internet.
I spent $600 AUD to buy my Homey Hub. This is āA LOTā of money in my country. I can buy a second car for this price.
I purchased it as it was advertised has having āApple HomeKit compatibilityā !!! plus also other features (which donāt really work properly after trying). The inbuilt IR and 433Mhz also really āNEEDā to have learning capabilities but Athom arrogantly donāt seem care about this after so much negative feedback about thisā¦
I can buy 3 x Habitat Hubās for $600 AUD. Even Apple donāt charge this sort of money. I expect a five star product for this price and that it perform what it advertises to do, and do it reliably. This is not so from my overall experience with the system. .
Im quite pissed off to ānowā find out that Athomās Apple HomeKit compatibility feature is essentially just a ājokeā to them⦠This is crazyā¦
HomeKit is such a major platform for smart home connectivity in the global market⦠Millions and millions of people use the IOS platform. Its nutās that Athom just treatās this with total contempt and disregard. Iām very disappointed in this information.,
If they donāt properly formalise this feature into Homey or they dump it Iāll be returning my Homey Hub back to the retailer for a refund.
Id dare say many people bought this hub as they thought it would āproperlyā integrate with their IOS devices . Iād dare say a class action will ensue if they donāt get their act together on thisā¦
Very disappointedā¦
Your comment doesnāt make sense. You first find out that the HomeKit delays/disconnects are caused by your setup (slow iPad functioning as HomeKit hub), you see that it works properly now but āwarnsā homey for any possible problems that come next. Donāt you agree that the initial problems seen have absolutely nothing to do with Homey?
Hi Hannes,
Firstly I never said I had experienced delays. I said that sometimes my iOS devices would not connect to a device but if I then tried issuing the same action āagainā with in about 30 seconds it would then work. A delay is when you issue an action , you wait a small amount of time and then the device then turns on ..
I also did not theorise that my connection problems were due to my iPad being slow. My theory was it might of been the cause in general. My iPad has the same processing power as a mid-range laptop..
When I wrote my post I said I had only been running the new setup for a few hours. Since then I have had a some connection issues. Iām currently going through my network setup at the moment and also checking that the new HomePod mini is setup correctly before I cast I final conclusion .. (Itās the first time Iāve had one of these)
You might also recall I also said i couldnāt get my system to pair up with Homey on the first attempt and I had to try twice. When you read through the Homey forum you will find a few posts from other people that have had major issues getting it to pair up ..
Now .. If you have being attention to this thread did you read Robās comments from before . ?
Rob is a developer for a few of the apps on the Homey platform. From what Iāve read he is highly experienced with the system and probably knows more about it (under the hood) than most people on this forum and also seems to be a quite an honest and straight forward person . (the people I like)
To remind you, this is what he saidā¦
and
Now taking into account what he said and that itās 2021 and Athomās HomeKit compatibility is still buried in the āexperimentsā section, it was never coded properly, it was hasty made, it hasnāt been updated in over a year and that Athom obviously donāt care about it (itās a joke to them. A Hackey Friday project
) and that people do experience issues with it (see posts from otherās as well) ⦠(my own issues are not concluded yet) are you telling me that there are no problems or issues with Athomās HomeKit implementation ??? . That is what your post basically implies ?
It must be my system thatās at fault. IT CANT BE HOMEY ![]()
You seemed to have also missed the overall bigger picture in what I wrote in my post.
When I get 20 straight days with no connection issues we can then say that my problem was āsolelyā due to my iPad . Im am currently still experiencing issues.. As I said before (without doubt) Athom āstillā needs to rework this App and get it up to scratch and also make it as a proper formal integrated app in the Homey system like they do with Alexa and Google Home.
I paid āBIGā money for my Homey.. $600AUD.. It was advertised as having HomeKit compatibility. I expect this feature to be properly integrated . I paid Rolls Royce money for this hub.. For this I expect hmmm āA Rolls Royceā !!! .. not a hub with āHackeyā Apps that were poorly and hastily coded and were then basically abandoned, with the intent to āsuckerā iOS users (like me) into buying their hub saying itās āHome Kit compatibleā
We are not just talking about a crappy little miscellaneous app that lets you know when your toast is ready. We are taking about Homey having connectivity to one of the top three ābiggestā home/mobile platforms on the global market.. As I said before .. TOTALLY CRAZY..
What are they thinking . Is Athom run by Monkeys ? or was it just the Directorās overall plan to get this Kickstarter project going to a certain point, make enough cash to buy say a nice house , a couple of fast carās , maybe a yacht or two and then just let it all fizzle out and walk away ? Some of the business decisionās that Iāve seen them make have been extremely backwards. Itās not just me. This is a well known thing.. Itās as if they donāt seriously want to get a foothold into the home automation market ., I canāt figure it outā¦
What can I say, I have 80+ non-compatible HomeKit devices presented through homey to HomeKit without a single issue (well maybe that sometimes it takes a second before the devices are updated in HomeKit but i wouldnāt really call it an issue). This is just me of course but it also means that there is a difference other than Homey because it can work properly.
Remember that the HomeKit experiment is very, very limited and I am not using that but the HomeyKit app
What would be the plus side for Homey over experimental? In my experience they do the same stuff and lack the same stuff. I cannot control thermostats on/off, only temperature. Rest looks ok.
But can you turn them on and off? MCO Home and termostat for floor heating seems to be not compatibile.
Yes, turn on, off, change temp, receive current temp etc.
Create a virtual device and add some flows and it will work fine
hmm could you help me with this? How creating virtual device allows me to control floor heating via Homekit? Right now i can ONLY change temp.
Siri shortcuts is the alternative when the hardware has not been certified to work with HomeKit.
Correct, this is the ideal approach if you are basically using this as a remote control solution as opposed to an intelligent self-reliant system.
Itās a pity that no one can be found to further develop Homeykit or that Athom has always advertised Homekit but has not done anything for years.
greetings
Philipp
