[APP] Yeelights LAN
Hello. Can you give me a fixed IP? It’s on a different network. It can’t find the light bulb.
I have five Yeelight ceiling lights (yeelink.light.ceiling3) in total. For years, they all worked fine in Homey via LAN control. Some time ago, one of them went offline in Homey, even though it is still visible and working in the native Yeelight Classic app. Restarting Homey and the router didn’t help. I then fully reset the light and was able to add it again in the Yeelight Classic app, but not in Homey. I can ping the light and control it through the native Yeelight app.
My setup: Homey Pro (early 2023) running v13.5.2, with LAN control enabled on the lights.
Any suggestions?
Check if you have enabled LAN control for given device.
Yes, I did it. Also turned it off and then back on again several times.
If the LAN Control is visible in the app AND enabled yet Homey still can’t see it… can you try adding the device and then send the diagnostic log? It’s strange…it should be discovered then.
