Thanks!
I had a look at the documentation, a lot can be done!
Anybody have some examples of how they use custom commands?
thanks
This is the wrong topic. This is for the Yeelights LAN app which does not depend on Xiaomi Cloud for control.
Ownership of this app has been transferred to @Sharkys . As an active member of the forum and a long time user of this app I’m sure maintenance and further development of the Yeelights LAN app is in good hands.
Thank you @Phuturist for all you did for community, not only with this app but also others - and thank you for nice words, I will try to do my best ![]()
New TEST version
3.1.0
Improved the pairing process and added buffers for device JSON messages to prevent random errors
3.0.19
New developer, code adjustment, logging improvements, migrate to HomeyCompose, enhanced logging for JSON errors
Feel free to install and use TEST version, in case of any issues, please send diag log describing issue and if needed, you can install back the stable version.
I tested the app myself for 2 days and so far did not experienced any issues nor minor errors I saw previously, so hopefully all is right.
Hi.
Is it possible to add an “and” card with “light is available / unavailable”?
Version 3.2.3 — Added AND cards for lights availability
However please note that when device is marked already as unavailable, you will get error state “This device is currently unavailable.” but whatever your use case is, I guess you can work with it already.
Note - Athom asked me to choose “invert” state card instead, so released new version
Hello
Can you add the support of yeelink.light.ceiling20, it seems that the plugin don’t detect it.
Best regards
After a repair in homey it works now with “yeelight” app but not with “yeelight lan” app, network isolation is disabled.
diag report sent with id : 6e79ddc7-745c-40c2-bfe7-96c45283c9a5
please give me any advice to fix this.
Yeelight is Cloud based, Yeelight LAN depends on the LAN protocol support from device itself. Please check your email, I replied you there.
There are 30 bulbs connected in the house with the Yeelight LAN app. It has happened before that the light bulbs did not respond, then restarting the Homey Yeelight LAN app solved the problem. Now, however, the apo works, the individual light bulbs can be switched, but they do not respond when controlled by the routines. If there are light bulbs of other brands in a routine, they run flawlessly, but the Yeelight bulbs do not respond. Restarting the Yeelight LAN app and Homey does not solve the problem either. Does anyone have an idea what the solution could be? Thank you in advance for your help!
Please control some of the lights from the app,then execute some routines and send diag.
Hi, sorry for being late. This is the report number: e3aeaa5b-3133-4553-962a-b37c601be25b
There isn’t anything useful in the log, I just see that 5 lights reported no info in the message…which lights do you actually have ? Can you copy here details of one of if the lights from the development portal ? You are not using any firewalls or VLANs, right
