Hello @Koktail My E1 Pro is not detect while my other Reolink cameras work OK.
Hardware version is IPC_513SD5.
Any clue?
Hi everyone,
I’m trying to set up my Reolink Video Doorbell with Homey, but I’m a bit confused by the available Flow cards. I’ve noticed that some cards (like “turned on for x seconds”) seem to be auto-generated by Homey and might not actually work, as discussed in some older forum posts.
Could anyone clarify which specific trigger card I should use to start a flow when the doorbell button is actually pressed?
I am using a [vul hier je type Homey in, bijv. Homey Pro 2023] and the [official/community] Reolink app.
Thanks in advance for your help!
Hi Koktail,
Sorry for my late reply, but my dog passed away and my mind is elsewhere right now.
I deactivated all flows. Then I created a simple new flow: If Camera 1 detects a person for 2 seconds, it should send me a push notification with a screenshot. The same error occurs here. I receive many push notifications, but 90% are without a person. It’s probably just motion detection or something similar.
The error only started after the Homey - Reolink app update. Everything worked fine until then.
The following second error is still present: There’s a contact sensor on a patio door. When it’s activated, by opening or closing the door, a push notification with a screenshot from Camera 1 is sent.
I used to have a flow that involved this contact sensor, but that flow no longer exists. The contact sensor isn’t currently included in any other flow either. However, the error/malfunction is easily triggered: I open the door, and then I immediately receive a push notification with a screenshot from Camera 1.
I’m at a loss.
Maybe it lacks a web server like my particular E1 Pro version, see quoted post below. This seems to make it “unfindable” by the Reo app.
It works fine with the Onvif Camera app however.
I’m really puzzled with all these problems. I have been using the ReoLink app since the first test version. And apart from the odd little niggle, that just needed a small setting change or restart of the app (to be expected with a test version) I haven’t had any problem with the PoE doorbell, 3 TrackMix PoE, Duo 3V PoE, RLC-1212A PoE, and RLC-823S2 PoE cameras that I have.
All 7 have been streaming their video and sound through my Homey Pro 2026 to the Homey App without problem. And the Advanced Flows I have created for each camera have worked, sending me person detection Push notifications, and loss of network connection Push notifications.
My doorbell being pressed triggers internal ringers, and turns selected smart bulbs around the house yellow for 30 seconds to notify me even if I’m listening to music. And it’s worked without fail. (I also have a smart lock, so if the door is left closed but unlocked for more than 10 minutes it announces so around the house, and sends my mobile a Push notification. And an Aqara contact sensor on the door, so if it’s left open for more than a set number of minutes the ringers can sound a bell and turn the smart bulbs red for 10 seconds.)
I guess it must be down to Network, Cameras and Homey inter-connectivity and configuration that’s causing all the problems, as everyone will have different set-ups and configurations. And it would be pretty impossible to account for every single different network hardware manufacturer and model, and every conceivable different combination so many different people could produce.
Much more detailed information is needed to successfully diagnose each different set-up and problem.
Sorry to hear about your dog, that is sad to hear.
For the issue you describe, don’t rely on the card “Camera 1 detects a person for 2 seconds”. Instead, use the trigger “Person detected” directly.
If switching to “Person detected” doesn’t resolve it:
Restart the app (or Homey if easier)
Trigger a motion/person event once
Send a diagnostic report
Then send me the report ID via email so I can check what events are actually coming in and which flow is being triggered internally.
This works well, thank you. For any other issue, i will tell you.
Hi. Ik heb het antwoord nog niet kunnen vinden, dus hoop ik dat iemand me hier kan helpen.
Ik heb net de Reolink batterij deurbel met de Home Hub mini gekocht, voornamelijk vanwege de integratie met Homey. Zoals eerder al in dit forum aangegeven is er geen trigger die doorgeeft dat de deurbel is ingedrukt, alleen dat de deurbel wordt ingedrukt voor X seconden.
De optie om niet de Home Hub Mini te gebruiken maar Homey rechtstreeks met de bel te verbinden is ook niet ideaal omdat je dan de functionaliteit verliest vwb de video/live/snapshots die niet aan Homey worden doorgegeven.
Is hier nu een oplossing voor die ik over het hoofd zie? Zoals het nu is lijkt me voor niemand ideaal.
PS: Mijn deurbel, hub en Homey zijn allemaal geupdate.
“Good morning! I also just use that card: ‘The doorbell is pressed for X seconds.’ If you set it to 1 second, it works quite well, but I agree that the name doesn’t really make sense.”
I just released v1.1.7 to production with a lot of small improvements : https://homey.app/en-nl/app/com.reolink/Reolink
v1.1.7
Pet detection now works on cameras that only report AI support via GetEvents
v1.1.6
Doorbell models now get the correct device type and capabilities
v1.1.5
Added support for Argus B440
v1.1.4
Fixed rapid ONVIF events being missed due to race conditions in alarm state tracking
v1.1.3
Fixed capability detection for older models that don’t support all API endpoints
v1.1.2
ONVIF events now automatically reconnect after a network timeout
v1.1.1
Added package detection as a new AI flow trigger and fixed NVR pairing timeout
After two restarts, the camera reconnected. Everything is okay.
Hmm I need to get back on this one.
I had the ONVIF app before for detection, but that didn’t work any more for several weeks. I tried this card Person detected, but without ringing the doorbell it actually triggers on a detected person. I’m now using @Linden85 option:
When testing it worked, so that’s promising.
Can we please have a simplified doorbell card or just a card for “doorbell has rung”.
The duration card really isn’t necessary for most use cases.
Tried both triggers and the ‘person detected’ was ass you said also triggered when not pressing.
The 1 second option didn’t work before but it now does, though it still feels like a workaround. I am just amazed why there is not a ‘doorbell pressed’ trigger.
