[APP][PRO] Zigbee2MQTT
“no Zigbee2MQTT bridge found“ is triggered because the default topic is wrong.
In the input field it states “defaults to zigbee2mqtt” however I had to enter “zigbee2mqtt“ manually in order to connect.
my topic is all lowercase, maybe the code states MQTT with capitals?
For the Aqara FP300, do you think it would be possible to also expose Motion and Presence to Homey?
In Zigbee2MQTT, the device exposes “Presence” and “PIR Detection” separately:
However, in Homey we only get one value, which seems to be linked to “PIR Detection”:
Probably. See first post how you can help get devices/ capabilities supported: [APP][PRO] Zigbee2MQTT
I’d really love to and I have done so in the past before ordering a sensor for you. But somehow right now, I am to stupid to find your instructions in the first post which I need to get the info to you.
Will check again later today.
Is this what you are looking for? If you think you need physical access to the device let me know your local price, then we can come up with a deal, just like we did before :clinking_beer_mugs:
“absence_delay_timer”: 30,
“ai_interference_source_selfidentification”: “ON”,
“ai_sensitivity_adaptive”: “ON”,
“battery”: 100,
“detection_range”: 16777215,
“detection_range_composite”: {
“detection_range_0”: true,
“detection_range_1”: true,
“detection_range_10”: true,
“detection_range_11”: true,
“detection_range_12”: true,
“detection_range_13”: true,
“detection_range_14”: true,
“detection_range_15”: true,
“detection_range_16”: true,
“detection_range_17”: true,
“detection_range_18”: true,
“detection_range_19”: true,
“detection_range_2”: true,
“detection_range_20”: true,
“detection_range_21”: true,
“detection_range_22”: true,
“detection_range_23”: true,
“detection_range_3”: true,
“detection_range_4”: true,
“detection_range_5”: true,
“detection_range_6”: true,
“detection_range_7”: true,
“detection_range_8”: true,
“detection_range_9”: true
“detection_range_prefix”: 768,
“humidity”: 50.9,
“humidity_report_mode”: “threshold and interval”,
“humidity_reporting_interval”: 3600,
“humidity_reporting_threshold”: 5,
“illuminance”: 19,
“led_disabled_night”: false,
“light_report_mode”: “threshold and interval”,
“light_reporting_interval”: 3600,
“light_reporting_threshold”: 15,
“light_sampling”: “low”,
“light_sampling_period”: 60,
“linkquality”: 168,
“motion_sensitivity”: “high”,
“pir_detection”: false,
“pir_detection_interval”: 30,
“power_outage_count”: 4,
“presence”: false,
“presence_detection_options”: “both”,
“schedule_end_time”: “09:00”,
“schedule_start_time”: “21:00”,
“schedule_time_raw”: 589845,
“target_distance”: 0,
“temp_&humidity_sampling": “low”,
"temp
&_humidity_sampling_period”: 600,
“temp_reporting_interval”: 3600,
“temp_reporting_mode”: “threshold and interval”,
“temp_reporting_threshold”: 0.5,
“temperature”: 20.22,
“update”: {
“state”: “scheduled”
“voltage”: 3003
They are both supported with Advanced Flows when connected via Zigbee.
I need to use this via Zigbee2MQTT since I use Homey Self-Hosted.
@Gruijter Could you help me provide the info you need?
My bad. This is what happens when someone (me) jumps in without knowing anything about the conversation. Apparently, I could not even be bothered to read the title.
