[APP][Pro] Zendure LAN - No internet needed!
Yup,
Thanks, I can use this → tonight I’ve planned to release test version 0.0.11.
Br
Dez
The mppt’s are working again!
Thank you so much!
Br
Vincent
-------- Oorspronkelijk bericht --------
I just installed version 0.0.12.
At first, I didn’t know what “New feature: Tile Combined Status Indicator introduced!” meant, but then I saw it when I opened the device view:
I understand the reasoning behind this and it’s generally a nice feature, but I don’t really like it, because having two different values in a single capability doesn’t really fit with Homey’s logic. I’m not sure if a capability like that will even be approved for the Homey App Store by Athom. However, I’m not an app developer.
This capability is probably just for display reasons and doesn’t seem to have any other function. Some of these values are already displayed on Homey’s own energy dashboard.
Or why not create a widget that shows some of the wanted values in one glance? There are already several Homey apps that offer similar dashboard widgets, particularly those related to EMS.
Another suggestion: with the Device Capabilities app, it’s possible to create your own virtual device with a status indicator that changes (link).
This isn’t meant to be a criticism, just a point of information and my personal opinion.
None taken, sharing your opinion and being critic in a positive way is something we need more these days !
Having said that, I have programmed the 'Combined Status Tile Indicator" because I encountered this as a shortcoming from (my) Homey.
Checking my Homey via my phone I noticed me continuously swapping between SoC and (Charge)power. (hence the TCSI)
Herewith a view I missed:
I understand the reasoning behind this and it’s generally a nice feature, but I don’t really like it.
Thanks and solution is easy, then simply don’t use it :upside_down_face:
I just got the message that the ZENDURE LAN APP is APPROVED and really live as official app now :partying_face: (so apparently they also like it :wink:)
Correct, see my picture above
The suggestions done I totally understand, but i’m using Homey pro 2019 (I like the light circle to display the actual home power consumption, which is not possible with Homey 2023.).
The Homey 2019 has limited RAM (I’m already using a swap file) thus installing extra app(s) is/are not welcome. (I already have sometimes performance issues).
Furthermore the dashboard (widgets) costs €25 for the 2019 version and being frankly honest, I don’t miss it.
Ps. And I like the KISS principle (Keep It Simple, Stupid :see_no_evil_monkey:)
Br,
Dez
Strange, I got this email today at 11:28 from Homey that the APP is Live, but apparently it isn’t…
@Dijker are you able to look what goes wrong here ?
Nope, just a Moderator.
Pls contact Athom support
Aaaaaah, my bad, that’s my other app I developed (Marstek B2500) and not Zendure LAN :see_no_evil_monkey:
Please ignore the “app = live” part in above posts :man_facepalming:
Br
Dez
The app looks good. Very nice that you now have the power and % of the battery on a tile. Would you like to see if you can make a control power charge and discharge power at the then. Now you have set of power but some charging discharged? Being able to set the load capacity is important for power limitation. For if again thank you very much for your use of your app.
Ps. You indicate reading the P1 meter but the smart meter with the ct coils also works fine.
Thanks for the compliment and the 'approval" of the TSCI feature !
Can you please indicate what you exactly need, because i’m struggeling to understand your request…
Thanks for this confirmation !
Can you please make a diagnostic report ?
  1. Open the Homey app.
  2. Go to Settings → Apps → Zendure LAN.
  3. Tap Create Diagnostics Report.
  4. Send the generated Diagnostics Report ID to the developer.
From version 0.0.13 onwards it will be included !
Br
Dez
Het rapport
418524e2-1e67-41e2-9f04-ab402d8c00ce
Sure, I don’t need to use the new TCSI values in the status display, that’s not a problem, but these values are still there in the overall overview. And there, the values are even displayed twice, which makes the view a little more confusing, in my opinion:
That’s the real point, what I don’t like. If we could just use this Values only as TCSI in the device tile, that would be ideal, in my opinion.
Congrats… :+1: :partying_face:
I totally get that. Before I had an HP26, I was also against “unnecessary” apps for the same reason.
Okay, I didn’t know that.
Marco3
Het rapport
Nice, I still didn’t had the info for the SolarFlow2400AC+, but now I have it :partying_face:
I’ll add detailed support/capabilities for the SolarFlow2400AC+ in the next release.
Thanks.
Br,
Dez
Clear !
It’s already possible in my app (see the hint button → red circle)
I’ll have a look at adding the max SoC limit. (need to see if that is technically possible)
Having said that:
  • dividing charging and discharging is more clearer => I’ll add those action cards
  • min Soc discharge limit is already possible, see green circle
Thanks for the info !
Br,
Dez
Top I hadn’t seen that.
The hint will only appear in a next version :upside_down_face:
Doing well with the app
Version 0.0.13 released for testing.
Not completely done with my own testing, (but need to go to bed :laughing:) so hope everything is ok :grapes:App
Changes:
  • Time in ‘last message fixed’ (UTC/winter/summertime)
  • code cleanup ‘status_message’
  • solar power added to Energy tab
  • readme.txt updated
  • SolarFlow2400AC+ support added
  • hint added in set-power action card explaining charging and discharging
    Br,
Dez
Entlade Leistung should also indicate a value… :face_with_raised_eyebrow:
Can you please make a diagnostic report when in the same situation (solar input and discharge), then I can find out what goes wrong.
I understand your problem, but still not sure what to do with you, because remove capabilities also means that the user is not able to add them to the tile status anymore… :wink:
Br,
Dez
