@martijnpoppen amazing work, just installed and was not even aware it was such a recent release, thanks a ton for the hard work!
Direct messages are working like a Blizz, will make use of the workaround via a second number though;
Group Messages are not working for me yet, seems like an encryption issue? Messages get sent and are readable by others but are not readable by myself “waiting for this message this may take a while”.
Also more like a general question, how does it work? considering the app gets access to all my messages I am curious whats the process behind it? Or do you basically have this open source client running on a Webserver and the homey-app is directly connecting to it?
Yeah saw the group message message today as well.
I pushed a fix for it in the server.
So the library i use has the capability of reading messages and act on that. But i removed that all from this integration.
Because it will consume a lot of resources / you’ll always shown as online / its not a good idea to do this on a cloud based instance.
During development i ran this integration natively on my Homey. Which worked fine on a HP19 but immediately crashed on a HP23.
For the data and authentication:
Homey connects to the server
the server has the whatsapp client running
the server send any data that has to be saved immediately to the store on your Homey
before every message the server initializes the client for your Homey
after sending the message the client is destroyed again.
the data stays on your Homey during that process
the sharing of data between server and client is done via a authenticated API with a JWT token and cannot be read by me.
Amazing, I just set up another number with WhatsApp-Business so now my apartment has its own WhatsApp account (lmao). That works amazingly well.
Great to hear you have a fix for the group message thing.
library capabilities: that makes a lot of sense, got it!
Any explanation why it worked well on the HP19 but not on the HP23? (shouldn’t the newer one be more powerful? )
Also thanks a ton for taking the time to shine some light into the process, I think this will be relevant for a lot of people to give some peace of mind, so I really appreciate it
I wish i knew. Really couldnt find it and it drove me crazy. This app already started in June. So i spent many hours and then decided to put it in the cloud.
My only guess that it has to do with virtualization on HP23 which HP19 doesn’t have
Still with one phone number connected on HP19 it was running at 45 MB ram. And 2 numbers on 65MB.
On HP23 it immediately spiked to CPU and Mem warnings and crashed in a couple of seconds
Maybe Athom will fix it sometime, must be a firmware issue for sure but thats some behavior I have seen with the Unifi App as well, completely crashed my Homey.
Do you think having it running in the cloud will be sustainable with increasing amounts of users?
NEW: 1: NEW: remove QR and use Code to pair with Whatsapp 2: NEW: use E.164 standard to validate phone numbers (Thanks for the tip @MarcoV ! )
FIXES: 1: FIX: pairing code stuck on pairing code screen 2: FIX: group links 3: FIX: message not sending due to client destroyed after previous message (debounce added)
More - apps - Whatsapp - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
With 14.4.4 I get to the stage where I can fill in the generated 8 digit code, but when I enter these in WhatsApp it doesn’t finish “Inloggen” status.
(with the v14.4.3 I also got $tmpl.login_credentials.invalid_credentials)
UPDATE:
It did work when trying to add a new WhatsApp ‘system’ using the Web Gui…
After entering the 8 digits in WhatsApp on my phone I got the confirmation screen on Homey Web App…
