[APP][Pro] WhatsApp - Simple. Reliable. Private
Choose the correct If card! Belonging to the right person’s number.
@EdNL checking in DM with you :slight_smile:
@martijnpoppen helped me a lot via DM. I am very grateful to him for that. Really great and it works great! Thank you!
New app update (:orange_square: TEST: 1.23.0):
Changelog:
NEW:
1: NEW: update library
FIXES:
1: FIX: pairing error
2: FIX: show error when something goes wrong
3: FIX: get auth failure notification
More - apps - Whatsapp - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Issue list: [APP][Pro] WhatsApp - Simple. Reliable. Private - #3 by martijnpoppen
New app update (:green_square: LIVE: 1.23.0):
Changelog:
NEW:
FIXES:
I lost my connection again.
Log: 6f339c75-8e9b-4db2-ad6d-6a713d7c0596
I hope that you see something
@Bulletcather I see some error codes. Will check and find out what they mean :slight_smile:
Good morning @martijnpoppen ,
Happy to see you again
Can this explain why the flows are not working?
Hi @Matthieu_Moreau
Sorry what do you mean?
I just started using this application, and for example this flows does not work.
@Matthieu_Moreau do you have a separate number?
Sending message to yourself doesn’t result in a notification and wont trigger the flow in Homey.
Same as in regular whatsapp sending to your own number doesn’t notify you
Yes it’s another number :slight_smile:
@Matthieu_Moreau can you try without the condition card and see if it works ?
I can’t change anything
If it helps, I’ll run it right after :
09e81c98-152b-48bf-9aaa-a6b7f3282ef7
@Matthieu_Moreau can you try a repair of the whatsapp device in Homey
In the webapp: right mousee click → repair
It works great, and the conditions too
Hi, I’m trying to pair my mobile with the app. I can install the app on Homey, I get the response on my phone, but when I enter the code given by your app, the phone rejects the code. I’ve deletedand/or repaired the device in Homey. I’ve rebooted bothe devices (phone and homey), no luck.
Here is the log: b73c05c8-2007-440d-8477-1c442c480b1d
What can I do?
@Pim_V Please send a report after trying to pair. right now the report is empty
d3c2e754-b81f-46cf-88e9-90f92d648530 after the pairing failed.
@Pim_V do you have any blockers in your network like pihole? The request to whatsapp gets cancelled as far as i see
