@Sharkys i think those are on the wishlist… see below:
@martijnpoppen i guess those will include action cards
Thank you Bug, hmm - I’m not sure if it’s the same, as it’s not just about the plug lock itself, it’s also about missing power source…but maybe you are right…
Yes correct @Bug that will cover the connection ‘state’. So a plug can be connected but not secured for example.
Same steps as before. And then send a diagnostic report.
@Sharkys the second one was for missing power while connected. I guess @martijnpoppen will implement both at some point
the not connected is already covered i guess…
Here is the diagnostic report
3a22ad94-63b1-4688-82f2-af0bb7799bc8
Start, stop, start, start with 61s delays
Changelog:
- FIX: Data stops updating after x amount of days. (Force refresh of state)
- FIX: climatisation start for ID cars
@Sharkys saw your report. this should fix it.
@peltsi51 made some changes in the request, let’s see what this does
It works! Starting only one time doesn’t work but when you make two or three times start command with 61s delay through a flow it goes through. This is the same as in iobroker implementation. Donation on the way!
Wow awesome!!
Thanks a lot !
I think the climatisation temperature should work too now
Hi Martijn,
when will the app be available in the store?
Hey @Hans_Maarten_Vink
Got a Nice breaktrough today.
One thing is left for me and that’s making sure all States are aligned between the official apps and Homey.
And I’m working on the branding/design of the 4 apps
So Lets say almost there
But to give a eta: 20th June
Setting of the climatisation temperature wasn’t working, tried from the device and with flow.
Hi Martijn, sounds great!
I think it only works if you set the temp and immediately start it.
Will have a look if I can hook up the start climatisation to the temp changer
