Thanks!
I have to check the differences between the SEAT API and the CUPRA API and see if it is possible
But as CUPRA now uses the same as VW and Audi some options will dissapear. That’s what we saw when VW and Audi updated.
Thanks!
@Tim_Messerschmidt can you share the flowcard you were referring to? So i can better check which value you would like
Changelog:
- NEW: update type on startup (All car models)
- NEW: Show error when new terms&conditions need to be approved again
- FIX: missing flowcards
Changelog:
Changelog:
Changelog:
Changelog:
- NEW: Update API
More - apps - AppName - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
@Tim_Messerschmidt see update above
Hi Martijn,
Is there any news w.r.t. the API update for the Skoda app?
I still get “Er zijn geen nieuwe apparaten gevonden” when adding a full electric Skoda Enyaq.
@Jos_Stultjens unfortunately not, still waiting for a update of the SDK
Its working.
Thanks.
Is it possible to open the trunk with a flow ?
@Ranesh_Harpal no unfortunately not possible
Helaaaaaaas.
But this is great.
Good morning,
He only sees the location of the car and he doesn’t want to charge anything else.
@Ranesh_Harpal Goodmorning
Please
Done
8f76a87c-eaf9-4a92-82eb-a6c4aaa83e00
same issue and reported
@Ranesh_Harpal It seems like your integration restored itself, the API was down for a bit but after that it came back.
You can check the “connected” card for that in Homey
@Tim_Messerschmidt you report looks good. Can you give a value which should be different? then i can check the response.
also can you try a restart of the app?
Tried restart
Several values show as blank in homey.
Distance
Tanklevel
inspection
battery level
and some more
@Tim_Messerschmidt please let me know the values you would expect. So i can validate them in the response.
distance: 39.782
inspection: 303 days / 15.400 km
Oil: 288 days, 12.100 KM
@Tim_Messerschmidt can you also send a new report so i’m sure i look at the latest data ?
