@Erik1986 yep nothing i can do at the moment.
Its as frustrating for me as well. These apps break every month now
Eufy, VW(set of), and Flow Checker are among the most challenging apps due to the constant API adjustments by their excellent developers Fortunately, we have Martijn to thank for navigating through it all!
PS: It’s not about flattery; it’s genuine appreciation for the hard work behind it.
Thanks @Sharkys
@martijnpoppen Can you just explain the difference (if any) to ‘Connection has changed’ and ‘Data has updated’ ?
Was trying to find the actual place in your source but no luck. Maybe I don’t have alle repos cloned …
@bwa dat had updated is after every parsing if data. Is connected should indicate if Homey is connected to the API or not.
We should just test it and figure out which one works
Yeah, ave added som logging so see how it behaves.
For other users I have testet the update rate, and found (for now) values that may be good to NOT get into rate limiting (HTTP 429)
I have set the refresha rate on myAudi to 3 hours at default, and when the car is starting to charge I change the rate to 60 minutes, and resets to 3 hours when charging is complete or car disconnected. In my usecase the SoC is not so important unless I charge, or if I connects the car to my charger, then it will fire a refesh as that point in time is important to calculate a precise charge-plan.
Never had 429 after this approach.
New app update ( LIVE: 1.24.2)
Changelog:
- FIX: resolve Rate limit
- FIX: Flash and honk command
- FIX: lock command
- FIX: window heating
- FIX: show connected state
Changelog:
- FIX: lock command
Changelog:
- FIX: lock command
Changelog:
- FIX: lock command
Changelog:
- FIX: lock command
More - apps - AppName - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Is anyone else having update problems with the VW ID? Mine has updated the values 12h last time with Homey. The android app works though.
Latest version 1.24.2 in use.
Almost the same issue here.
Our e-Golf hasn’t updated data for more than one day, the iOS app do work.
Now running 1.24.2.
My secondary account in the tool shows position only while the owner account shows all in the tool.
Car did not update anything sinds 11hours.
Guys not sure why as the API is recently updated…
As far as i know there are no new updates available
Only thing i see in your logs @Bug is that all data is missing in the response
New app update ( LIVE: 1.24.3)
Changelog:
- FIX: prevent restarting when API returns no status
Changelog:
Changelog:
Changelog:
Changelog:
Small fix to prevent a login loop when the API hasd no data available
Sent also a diag report if it helps.
df457588-06d7-4cd6-b5ee-50620dcc6bf7
Looks like the API has changed again. Not much i can do. We’ll have to wait for a update. Again…
Skoda, VW & AUDI API
there are issues with the API again. Therefore this app will probably not function at the moment for the above mentioned brands
Status: VW-ID -Status Data not up to date · Issue #299 · TA2k/ioBroker.vw-connect · GitHub (Audi and Skoda use the same API)
New app update ( LIVE: 1.24.4)
Changelog:
- FIX: update library
Changelog:
Changelog:
Changelog:
Changelog:
