Hi Andi,
thanks for your nice work.
I see the data polled from the data portal in the JSON in debug, but it is not transfered to the capabilities in my case.
70417691-97c6-463e-bcd6-9023cae4f979
Cheers
Tobias
Hi Andi,
Cheers
Tobias
Could you please share your JSON data (under app settings)?
Sure ![]()
“vin”: “TMBJH9NY1xxxxxxxx”,
“user_id”: “dc964aac-6e08-xxxx”,
“Data”: [
“key”: “0a18a053-b4b0-3db1-be44-a6c5dba629b1”,
“dataFieldName”: “currentSoc”,
“value”: “59”,
“timestampUtc”: “2026-07-31T06:41:17.181Z”
“key”: “62a0652d-2dae-32af-9404-4879cf6f669a”,
“dataFieldName”: “persLocation”,
“value”: “[51.042301,8.67465]”,
“timestampUtc”: “2026-07-31T06:41:17.196Z”
“key”: “8a5df67d-839f-3117-be3b-6f09d345ebfa”,
“dataFieldName”: “shortTermAverageConsumption”,
“value”: “14.4 kWh/100km”,
“timestampUtc”: “2026-07-31T06:41:27.084Z”
“key”: “bfd914a7-e030-3dc1-99f4-93d3b945da07”,
“dataFieldName”: “speed”,
“value”: “0”,
“timestampUtc”: “2026-07-31T06:41:27.228Z”
“key”: “5150d35f-9f5d-3f61-b8d5-8bdca8178448”,
“dataFieldName”: “tripId”,
“value”: “fdca8c5e-9828-4f26-8cc4-db9b504acb8e”,
“timestampUtc”: “2026-07-31T06:37:22.774Z”
“key”: “56bc8dc1-e326-3da8-b0d0-8c5519001c17”,
“dataFieldName”: “heading”,
“value”: “159”,
“key”: “85807008-0add-3e9c-86a7-949a07334e8c”,
“dataFieldName”: “ignition”,
“value”: “keyContact”,
Skoda Enyaq from 2025, all data selected on EU data portal.
Cheers
Tobias
has anyone else encountered the issue of the same datafield occuring multiple times in the same JSON file? I have 2 SOC-values in the file and the first one (86%) is an old value that keeps on popping up and the Homey app reports that one instead of the current value (76%). I also contacted the drivesomethinggreater.com about it, but am still waiting for a reaction.
"key": "7bddd5e7-43a4-3878-bd63-9502782f77a5",
"dataFieldName": "battery_state_report.soc",
"value": "86"
"key": "506cb83e-f99f-3af3-bbeb-0429b69a78d9",
"value": "76"
according to the documentation:
the first one is “State of Charging when charging is started”
the second one is “The int value of “battery state report soc””
the second value should be used for the SOC displayed in the app for your car.
for my hybrid Golf 8.5 GTE it reports the SOC fine in the app by the way…
@Bug Thank you for the hint
@Lifevolution Please check new TEST version: VW Group Vehicles | Homey
Hi Andi, great update, and @Bug thanks for the helpful insight!
The result is dat when both values are in the JSON, the first one (= the right one, also identified by the key) is being used. Unfortunately this morning I noticed that the second SOC value was being used. When I looked at the JSON file the “first one” was not in there at all, so only the second SOC was being reported and apparently that value then is used. I don’t know how to resolve this issue, other than always exclude a certain key?
Good catch — you’re right, and that’s now fixed in 0.0.49.
The charge-start value is never the current SOC, so falling back to it was wrong in principle. It’s now dropped entirely instead of just deprioritised. When a dataset contains only that entry, the app reports no SOC for that poll and keeps the last real measurement — an older but genuine value rather than a charge-start number that could be days old. The next valid dataset takes over immediately.
I deliberately excluded only that one key rather than whitelisting “known good” ones — otherwise vehicles whose live SOC arrives under a key I haven’t catalogued would stop reporting altogether.
One open question: your data also had a third key, 93b55324-…, reading 90 where 84 was correct. I’ve left it alone since I’ve only seen it once. If it turns up again next to a known-correct value, let me know.
So far the fix seems to did the job, thanks! I haven’t seen the 93b55324 key since, but if it returns and has impact, I will let you know.
Hi, thank you so much for your work.
It look liked since the last update the app won’t refresh anymore. In de debug en JSON files are the timestamps right. But the info in the app is old.
After a re-instalation, I still have the same refresh problems in your app. Can you help me to fix this?
Thanks for reporting this — the detail that the JSON timestamps were right while the app showed old values is what pinned this down, and I could reproduce it.
It’s a bug in the app, not your setup. The app decided whether a dataset contained anything new by looking at the newest timestamp in it. Some vehicles include an entry stamped with a fixed date in the future (a validity or due date), and that permanently became “the newest” — so the app concluded nothing had changed on every single poll and stopped applying readings, while it kept downloading and storing fresh data. That’s exactly why the Debug tab looked correct.
Fixed in 0.0.64: readings are now always applied, and future-dated entries are no longer mistaken for measurements. No action needed on your side beyond updating — no re-pairing, no portal changes.
Please test newest version: VW Group Vehicles | Homey
I installed everything according to the instructions in the app manual, but in Homey it says “no reaction.”
The files look like this: 20260908185749_WVGZZZE2ZNE006150_no_content_found
It seems that something is not working correctly.
Those …_no_content_found files are the portal’s placeholder for “the vehicle sent nothing in this 15-minute window” — the fact that you get them on schedule means your continuous data request is active and delivering. What’s missing is data from the car itself.
Three things to check, in the order that most often helps:
Data sharing in the vehicle. In the car’s privacy/data settings, data transmission must be switched on. This is by far the most common cause — if it’s off, the portal will keep producing empty snapshots forever.
Data clusters on the portal. Open your continuous data request and confirm that data clusters are actually selected. A request created without them delivers empty snapshots indefinitely.
Wake the car once. Many VW Group vehicles only report around a drive or unlock cycle. Drive or unlock it once, then wait for the next 15-minute window.
Tried and checked all but without result. So it should be something on the VW portal?
Any idea if it’s possible to contact VW?
Had the same issue with “no content” for a week or so.
There’s a Contact us button on the bottom of the Eu.data.act page where you can explain the issue. They replied on email after a few days, and the issue was solved.
Hi, great work with the app!! @Andi
Would it be possible to add last updated timestamp to the car widget like it is in the Hyundai widget here?
Hi Kraakenes
Please install the latest TEST version: VW Group Vehicles | Homey
4bab9539-a026-4e1a-98ce-a02913fd994d
Gewn reactie meld homey
Heb alles opnieuw gedaan maar zonder resultaat
Krijg wel om het kwartier een rapport.
Dus benieuwd wat ik fout doe of waar het mis gaat
Hoor het graag
in English please
No response from Homey.
I’ve tried everything again, but with no result.
I do receive a report every 15 minutes, though.
So, I’m wondering what I’m doing wrong or where things are going wrong.
Looking forward to hearing from you.
