[APP][Pro] VW Group Vehicles - Access your vehicle data via the EU Data Act portal for VW, Audi, Škoda, SEAT, Cupra and Bentley
Hi Mark
Could you please update to the latest TEST version: VW Group Vehicles | Homey
and send me afterwards the JSON (under App settings / Debug)
great work!
I will send when i did this
Sorry
But jason keeps empty
See only this in homey
ey
Hello Mark, not sure whether you are aware, but please consider using the following options when posting logs, code, etc., to increase readability of your post:
  • Preformatted text option to keep the output in the original format and presented in a scrollable window. This reduces the length of your post.
  • Hide details option, to collapse/hide the entire interview output. Clicking the collapsed item will show the interview output again.
Good news is hidden in that message: your subscription is working. Getting a file every 15 minutes means the delivery is running. They’re all named …_no_content_found, which is the portal’s way of saying the vehicle sent nothing in that window — so the problem isn’t between Homey and the portal, the car simply isn’t providing data.
Don’t press “Try to repair” — your log shows the login working fine, so that won’t change anything.
Three things to check:
  • Data sharing in the car — in the vehicle’s privacy settings, data transmission must be on. By far the most common cause.
  • Data clusters on the portal — open your continuous data request and check that clusters are actually selected.
  • Wake the car once — drive or unlock it, then wait for the next 15-minute window.
    Also: you have three devices for the same car in Homey, one with a dead subscription ID erroring every 30 minutes. Delete the old two.
Best,
Andi
For some reason i’m keeping “no content” as well. I’ve been waiting for a couple of days without any luck. As i had chosen “All data” earlier i’ve removed the previous data files and now chosen all packages (all+the others) to be 100% sure. The car has been driven plenty, the clusters are chosen and data sharing is on (Audi homey app worked earlier). Anything i’m missing?
As there is no data in the zip file I recommend contacting them directly: VW Group EU Data Act Portal via e-mail: euda-support@cariad.technology
If anyone experiences an issue starting tomorrow, here’s the reason - and maybe some issues get fixed:
I tryed also all data again and checking all boxes with no result. They keep empty. I send a mail and will see what they say.
Hope they can solve it.
Exactly. I also contacted them and it’s fixed!
Thanks :slight_smile:
Hi
Im the owner of an ID.3 and ID.Buzz electric offcourse :slight_smile:
I get a lot of data from the car by this app, but I wonder, what about “Service Warnings” Tyrepresure etc?
My car doesn’t have any warnings right now, but will they also appear here?
Hi Gert,
Three different answers, depending on which part you mean:
Service intervals — yes. If your car reports them, you get distance and days remaining until the next inspection and oil service as separate values you can use in flows.
Tyre pressure — maybe. The app has capabilities for all four wheels, but it only shows them when the vehicle sends actual pressure readings. In the datasets I’ve seen so far, VW sends only validity codes rather than real values, and the app deliberately shows nothing instead of a made-up “1 bar”. Whether your ID.3 or ID.Buzz sends real values, I genuinely don’t know — I have no dataset from either model.
The warnings themselves — no, not yet. Your car does send fields for a service warning and for active warnings in the instrument cluster, but the app doesn’t read them today. I left them out on purpose: I’ve only seen them on a vehicle with no active warning, so I can’t tell what the values mean, and guessing would mean showing you a warning state that might be wrong.
That’s where you could help. Open the app settings, go to the Debug tab and copy the raw JSON for one of your cars. That tells me exactly what an ID.3 and an ID.Buzz deliver — especially whether real tyre pressures come through. And if you ever do get a service warning, a second copy at that moment would settle what the warning field actually means. With those two I can map it properly instead of guessing.
Best,
Andi
c2356c12-93bb-4906-82ee-6b4faf886c5f
I followed all the steps and think I am receiving the correct data from skoda because I see the state of charge in the json. However now cant seem to get the state of charge working in the app.
Found a real bug from your log: when the portal splits a dataset across several JSON files in one archive — one per data cluster — the app only read the first and discarded the rest. That produces exactly what you saw: six fields, no state of charge. Fixed in the next version.
If the state of charge is still missing after updating, could you paste the JSON from the app’s Debug tab? That tells me whether it’s a field name we don’t yet map.
Please use the new TEST version: VW Group Vehicles | Homey
Wow that was quick! Its not fixed in the test version unfortunately. Here is the JSON:
“vin”: “xxxxxxxxxx”,
“user_id”: “yyyyyyyyyyyyyy”,
“Data”: [
“key”: “b06b7c81-2de5-3aa3-847c-4ee16a56233b”,
“dataFieldName”: “inspectionOilDistance”,
“value”: “12100”,
“timestampUtc”: “2026-09-21T15:02:18.200Z”
“key”: “c5b624db-6a07-3957-9127-98cee0be6c98”,
“dataFieldName”: “boardnetBatteryVoltageIndication”,
“value”: “14.3”,
“timestampUtc”: “2026-09-21T15:02:16.939Z”
“key”: “ea58e713-ef44-3150-9303-edfc519dcdc1”,
“dataFieldName”: “inspectionDistance”,
“value”: “12100”,
“key”: “b871c390-5325-377d-a91f-ea09bc0eff92”,
“dataFieldName”: “outsideTemperatureIndication”,
“value”: “19”,
“timestampUtc”: “2026-09-21T15:00:56.908Z”
“key”: “ce16f6c8-f565-3f9a-bddd-4acd12a41741”,
“dataFieldName”: “secondaryEngineBatteryStateOfChargeIndication”,
“value”: “37”,
“timestampUtc”: “2026-09-21T15:01:56.911Z”
“key”: “4d984161-147b-3297-8175-d87f2e991af9”,
“dataFieldName”: “fuelLevel”,
“value”: “68”,
Got it — my first guess was wrong, your dataset really does contain just those six fields. The problem is the naming: your Kodiaq reports in camelCase, and three of those names weren’t mapped — including secondaryEngineBatteryStateOfChargeIndication, which is your state of charge (37%). Also fuel level and distance to oil change. All three work now: 7 values instead of 3.
Your dataset is still narrow though — no mileage, range or charging state. If you want those, add more data clusters to the continuous data request on the portal.
Please test: VW Group Vehicles | Homey
I thought the data was the problem initially so I set it up a second time and made sure to check ALL DATA… Its not showing up in the debug tab though.. Battery level is showing up correctly now! Could it be that the data is not in the json because the car is parked and not charging? Will it then leave the data out?
I checked the car and it already was connected to the charger.. it chared to 80% and the data is showing 37%.. I set it up to update every 15 minutes on the data portal thingy but it seems not to update when the car is parked
Your data is from 21 September, 15:02 — three days old when the app read it. The portal keeps producing a fresh archive every 15 minutes containing that same old snapshot, so nothing looks wrong from the outside. The 37% is simply what your car last reported; the charge to 80% never reached VW.
That’s between the car and VW, not the app — but the app should have told you. It now measures age from the car’s own timestamp instead of from when it polled, so a stale reading is visible instead of looking current.
Worth trying: drive the car briefly, or lock/unlock it, and see whether a new timestamp appears. If it stays on 21 September, the vehicle has stopped pushing to VW. :frowning:
