[APP][PRO] VThermo
Anyone here who uses the aqara E1 thermostat togeather with Vthermo? Have anyone made the thermostat open to 30 C° when heat turns on and return to 5 C° when heat turns off? The situation now is that the thermostats only opens slightly over the room temperature causing a very slow heating process :sweat_smile:
Hi I am little confused regarding the Zones
So I have my Homey set and is called Home
I then have several zones (rooms) set up homey mots of the rooms have a tado thermostatic valve (which I would like to replace at later date with Aqara ones) and I have added a VThermo to all the rooms that have a Tado valve. have gone into advance settings and setting an set the following in
Temperature sensors in the same zone
Temperature sensors to yes
others thermostats to yes
Temperature sensors from the parent zone
Temperature sensors to no
others thermostats to no
Temperature sensors from sub zones
Control devises in the same zone
Heaters yes
Thermostats yes
Control devises in the subs zone
Heaters no
Thermostats no
The problem I have is if I try to adjust the temperature on VThermo it will just revert back to what is was set before if I adjust the temperature on the Tado valve in the homey app ti will update the temperature on Vthermo
Have I missed some strings some where
Thanks
Eddie
Does this app work?
This app is for adding virtual thermostats, when we have only temperature sensors and a on/off heating source. There’s no reason for using it in combination with a real thermostat.
thanks , i had the same pb with the temperature from a Qubino dimer.
same pb for me today.
Any ideas ?
Hi, I played around in the
“Advanced settings” of my Vthermo’s.
“Temperature calculation method” was, in most of them, on “Average”.
I changed it to “Maximum” or “Newest” and the “Phantom” temperature values disappeared.
“Average” setting kept giving strange results, with the exception of 1. This one is working correctly.
Never found out what the problem is, but it is working (I restart the app 2 x a day).
Paul
Update 2026-01-08
My last “Average” setting also stopped working (Phantom” temperature values). Also I changed it to “Maximum” or “Newest”.
Paul.
Did you find a solution to this? I have the same issue now, running latest version on HP19. Temperature not updated in vThermo, and Vthermo not turning heaters on/off.
I have found no other solution but to reboot homey on a regularitet bases. Testing now with once a week
I have a little issue which I don’t understand.
I created a zone an place in this zone Vthermo and my Tado thermostat.
In the Vthermo settings I set that updates should be synced between both of them.
Now the strange part, when my TADO changes the set temperature the Vthermo changes to (as I expected_ but when I change the set temperature on the Vthermo I would expect this is updated (according to settings) also to the TADO thermostat, but this does NOT happen…
So it is synced but only from TADO to VThermo but not from Vthermo to TADO.
What do I wrong here, how can I get full sync (both ways)?!
Rebooting both app and Homey doesn’t work, Al vthermo not updating from temp sensors, and not activating heaters. I have on vhumidity instance (with data from same sensor), this one works fine.
I’m sorry to tell, but the latest update (to v1.11.1) was broken. The sensor temperature is not refreshing in the app, and therefore the thermostat does not work no longer. Both the app and Homey restarted without affect.
Can you create a diagnostics report ?
Go to settings for the app, and click on the “create diagnostics report” button
Hi, generated with an ID:
80b72912-f959-4238-942e-a7e53281bca5
Thanks. No crashes or errors in the log.
Can you test adding a new Vthermo device to a zone with a temp sensor, and check if that works?
I woke up to an issue with the thermostat. Suddenly the under floor heating was back on.
I use VThermo to control HeatIT Z-water, and after recent updates something made the thermostat work, even though it was turned off, and then turning on the underfloor heating. I haven’t figured out exactly what’s happening. But it was a couple of warm days in the house before I figured out what was going on.
Turning them on and off (a few times) seems to have fixed the issue.
Also the touch control for the “wheel” is not working very well.
Report: d48fbb29-79f5-4fc0-89f0-6cf4d905e739
I am using vThermo with Homey Heating Scheduler. Before 13.4.0 I could leave the heating plan on, turn the vThermo off and then control the device manually. Now it seems that the vThermo isn’t really off until the plan is also off. The device behaves as if it was still connected to the plan.
This broke many of my flows. I am now having to mess around with manually updating target temperatures in the vThermo.
Hi
I have homey pro early 2023.
After having run smoothly for a long time, vthermo doesn’t sync with temperature. This happens chiefly in one rom and occasionally on another room also.
When this condition ie detected, th vThermo app is restarted. This doesn’t help for very long.
When I restart Homey, it works OK for about a day
Can you please help me?
Same here, vthermo doesn’t update unless the app is restarted.
I circumvented. A flow, when sensor temp changes, then set sensor temp in vthermo, delay 5s.
Works OK when only one temp sensor.
Comments?
