Just installed Volvo on call and I added my VCC API primary key.
When trying to add the car I receive this message « token refresh failed »
Any idea?
Any idea?
My car just got unavailable again (I think it’s once a week or so by now) and I sent in a log if it’s of any help: 07e398bf-7916-4405-b2e6-f3b1df73ffb4
all the best
My cars become unavailable approximately every 6 hour… ![]()
Is there a solution to this? I have to login with my volvo ID credentials to have them online again for about 6 hour
As you may have noticed, there have been several releases attempting to solve the problem, the most recent one being yesterday. If it were an easy problem to fix, it would have been resolved by now. I appreciate the diagnostic reports some users send me, but even with those, it is hard to understand what is happening. We have a refresh token that is supposed to be valid for a certain period, but then it suddenly becomes invalid. I still appreciate getting the diag reports; the latest version has even more logging.
As I mentioned before, we are using the client ID and secret from one account (mine) and the VCC API key from everyone’s account. This is not the intended usage and might be the reason for the issues we are facing. Feel free to encourage Volvo to allow my Easee app registration to make a large number of API calls per day so that we can use the official client ID/secret/VCC API key setup. They didn’t bother replying to my email.
Richard. It doesnt matter if you manage to solve this or not. We still appreciate all the work you put into this. Thank you ![]()
I agree with Albin. Thanks a lot for the time and dedication you put in to this. ![]()
My car became unavailable approximately 1 week after the new update: 60ddd627-9128-47d5-b9d7-e6f7685fad70
Wanted to install on HP23, but encountered this::
{“code”:429,“error”:“too_many_requests”,“error_description”:“Too many requests.”}
Please add odometer (mätarställning)
Great Job on the App, but I haven´t been able to connect my V60 (2025) since 9/1-2026. Am I alone with this issue? (V1.5.8)
No more connections issues since at least december (v1.5.8)
Same here ![]()
I had Claude Opus 4.5 do a big refactoring of the entire OAuth code, and remove all dependencies. The app is now much smaller in size and should consume less memory. The latest test version requires Homey firmware 12.9.0 (Node v22) or higher, this in order to get rid of the node-fetch package.
Available in the latest test version, v1.6.0
Been running if for a few days now. So far so good ![]()
Hi, I’m trying to install the app / connected vehicle device.
I added the API key in the app’s settings. Then try to add the device. After logging in with my Volvo ID I get a “Token refresh failed” message.
Any ideas?
Nobody?
Thanks for your reply, I’m on app version 1.6.1 which is the latest (stable). Tried removing and re-installing but issue remains.
After logging in with Volvo ID I get the token refresh message.
v1.6.1 is the latest version, been running for 3 weeks on my Homey without issues ![]()
Are you using the android app, maybe you can try using the web app.
If still not working do as @FKey proposed, send a diag report. Note that the diag report will only contain relevant logs if you send it right after you test the action and get the error. Sending a diag report hours later, or after an app restart makes sure nothing relevant is in the report.
Actually got the same issue as Jo_San.
I sent in a report as well.
a60ed02d-4f1f-463f-99c7-e416d20d10ca
Let me know if I can help out in anyway!
