[APP][Pro] Volvo on Call - Connected technology that makes your life easier
Okay, found A issue and it’s not your’s @Richard_B ..
The Copy button in Volvos API page doesn’t copy the actual value.
Seen this in Atlassian as well using a chrome based browser.
Pressing the copy button give you one value..
Viewing the key and then marking and copying actually gives you the key in the field.
I do the OAuth error though..
I can’t reproduce any of the errors, but did some minor changes. There is a new test version.
Not sure what you changed but it worked beautiful.. :smiley:
Thanks!!
Hi
I added the API key in the app’s settings. Then try to add the device. After logging in with my Volvo ID I get a “Token refresh failed” message. I have app 1.6.6.
71a5383e-7ac6-4bd8-8bab-d0cd2dd053c2
Hi Richard. Thanks for bulding and maintaining this app. Question: Would it be possible to add more tags/cards to automate with? I seem to miss some. I would like to be able to open and close windows -for instance- with a a button (Virtual Device). Same with pre-climitisation: i can get the start of a trip from Google agenda and give the command to start climitisation 15 mins prior to that. But I cannot see if climitisation is running. In the Volvo on Call app on my phone that information is available.
So giving commands in a flow workes, but I cannot use the status in a ‘and-card’ or a variable. Would be great if this could be added. Thanks a lot.
EDIT: I also miss the flowcard : if climatisation is started (or is on).
Apparently, we must renew the token at intervals (every 6 months), it would be nice to have a link and a guide in the app itself as you easily forget how to do it.
There is a 6-month limit, but it’s on your Volvo login, not the VCC API key.
Volvo’s developer docs say a login session can last at most 6 months, even when it’s refreshed regularly (Authorisation docs). After that you have to log in again. In Homey, the car will show as unavailable with a message asking you to re-authorize. To fix it:
Devices → your car → Settings (cog) → Repair, then log in with your Volvo ID (the email and password you use in the Volvo Cars app).
You don’t need a new VCC API key for this. Volvo doesn’t document any expiry for the key itself.
If you get an “invalid VCC API key” error, that’s a different problem. Check these:
  1. Log in to developer.volvocars.com and make sure your application still exists and is active. Volvo can disable applications, and a few people have fixed this error by re-enabling theirs.
  2. Copy the key again from the application page and paste it into Apps → Volvo → Settings. Watch out for a space at the start or end.
  3. If it still fails, delete the application and create a new one, then paste the new key into the app settings. You don’t need to publish the application.
Hi Richard,
Suddenly, I can no longer lock my Volvo EX30 through Homey. I’m getting the error message shown below.
I’ve restarted the app, repaired the device, installed the latest test version, and restarted Homey.
Is there anything else I can try myself?
Suspect Volvo have changed so we cant send an empty POST body. I just released a new test version, can you give it a go :+1:
Everything is working again as it should. Thank you for the quick fix!
Volvo app 1.8.0: please repair your car once after updating
Currently released as a test version
Volvo is moving Volvo ID to a new sign-in service, and the old one stops working on 31 January 2027. Version 1.8.0 switches the app to the new service.
What you need to do
After updating to 1.8.0, sign in to Volvo ID again once:
1. Open your car in the Homey app.
2. Go to Repair.
3. Sign in with your Volvo ID and approve access.
Your car keeps working for a few minutes after the update. When its current sign-in expires, it shows as unavailable with a message asking you to repair. Repairing fixes it straight away, and your flows and settings are kept.
Your VCC API key does not need to change. I’ve tested both existing keys and keys from newly created applications with the new sign-in. I hope this is a consistent experience for everyone.
Hi Richard,
After the update and the repair, everything is working again. The vehicle was indeed unavailable, but logging back in resolved the issue.
Thank you for all the effort you put into this app. It’s much appreciated! :blush:
Unfortunately, it doesn’t work very well after all. I’ve reverted to the previous version.
1.7.1 also not working anymore
Version 1.7.1 hasn’t changed, so if that is also failing, the problem is on the Volvo side
Hi Richard,
I did some more testing. With version 1.7.1 I can read the vehicle data correctly, but I cannot control any functions. After reinstalling version 1.8, everything works again, including the controls.
However, this appears to be only a temporary fix. At the moment version 1.8 is working, but the issue may return later.
Hopefully this information helps with troubleshooting.
Thanks again for your support.
Kind regards, Stijn
Hi Richard,
Everything started working again automatically with version 1.7.1.
Thanks for your help!
Great! Matches my experience as well - there was an initial glitch, but since then it has been working fine :+1:
