Nothing helps to remove the error now unfortunately.
On the positive mote, the change you did, changed the behaviour.
Peter
No, the external switch doesn’t work. The sleep internval did work, I think.
Now, I have installed the new version but the removal of the sensor hanged on a blank screen and the same happens if I try to add it again.
That’s strange. Maybe try a restart.
Add/removing is not necessary when installing a new app version
Ok! Now no devices regardless of app can be added. All stop on “Follow the instructions” and blank screen.
How do I do restart?
Edit: Did a power off / on…
Yeah I would say a power on/off
But maybe try reset the device? If the exclusion went wrong the device still thinks it’s connected while Homey says it’s not.
I cannot start ANY inclusion, regardless of the make. Telldus or Fibaro, same issue.
Great work. Have successfully added the ZD 2105 Recessed Door Sensor and the ZD2201 4-in-1 Multisensor. Will do some testing and advise further. Donation on its way. Thanks.
@OzFrog
Awesome will put the changes live soon
(might take some time because Athom needs to validate).
And thanks! appreciated
hmm. Maybe try a PTP [HOW TO] ptp
Edit: I also had it once. It seemed like the z-wave driver was not started succesfully.
btw: you can see logs of your Z-Wave network here: Homey Developer Tools
Ok, I will try that! I will pull it and leavi it over night.
Sure! Will continue tomorrow! have a nice evening
Really sorry, Martijn, but it seems that I got the specs mixed up. The Recessed Door Sensor is Product ID 7952 and the Multisensor is 8705. Could you swap them around please? Sorry for the inconvenience. Robert
Got everything generally ok now!
This still is the situation, I cannot enable the external input:
This error was not from the beginning.
Edit: Reinstalled the realeased version and then the parameter can be changed. (But the external switch still don’t work)
@PeterW Thanks for checking.
Can you do the following:
- try to change the settings for the external switch (of course you get the error)
- send me a diagnostic report. (then i can check what goes wrong)
f498ff46-0626-42bb-a510-3799089ba1e5
In the process of getting back to normal, I uninstalled the app. I then reinstalled the 2.5.0 version and added the sensor.
After that, I could change the parameter to Yes.
After that, I installed the test version.
Now, the parameter in set to Yes and cannot be changed to No.
Took the diagnostic after trying to change the parameter.
External input still do not work however.
Will check and let you know later tonight
Nope, same problem.
Have in mind that the configuration change works in 2.5.0
