[APP][Pro] Velux
Hi Peter, thanks for the app.
I have an issue with the flows and sometimes the blinds wont open. I saw in the configuration section there is an input for the papertrail.com platform to send the logs, but it is complicated to open an account there.
What do you suggest I could use to get hold of the logs and see what is really happening ?
Cheers,
JS
Hi JS,
It sounds like a connection issue, but i will have a look if you put the following into you papertrail settings (in the app configurations):
Papertrail Host: x
Papertrail Port: x
(removed)
Best,
Peter
Oh, thank you very much, i am going to input that right away.
If everything is fine, you should see calls for curtain opening in the morning (around 6:20) and calls for closing at dusk.
They actually close but not open :sad_but_relieved_face: . I have to trigger the opening manually because the flow doesn’t open them.
Hi JS
I can’t see any logs from you, but it might be on my end. Will you please click on one of your devices in homey and send me the full url
Will look something like this
https://my.homey.app/homeys/640eca400xxxxx958954b8/devices/604b3a63-xxxx-xxxx-xxxx-b5acfbdda79d
Best
Peter
Hervé, I bought a Tohoma Switch and tried to make the IO transfer as you described in your French manual. Am I right you choose “Transfer IO key” and not recieve an IO key. And after this choice, you have to select a compatible device. Is that “Other, compatible with IO home control”.
I did not got this working and have manualy installed the velux windows in Tohoma
Hi Richard,
Yes that’s right. You don’t receive any IO key by yourself. The TaHoma will transfer this key and that’s the Velux Active Box that will receive it.
After having selecting “Other, compatible with IO home control” on the TaHoma app, have you done the final manip using the Velux Active box ? See below
Oké, clear. But using the Tahoma Switch directly in Homey and address the windows in Tahoma Switch the Velux Active is not necessary anymore, right? So why did you made this workaround
Okey, great :slight_smile:
I also used the Velux Active because I already had it, and Velux told me to do so ^^
Fyi, I had a Velux KLF-200 from an earlier project and I have just created a proof of concept APP that works with Windows for now.
Does this also mean that for control of blinds I can use tahoma?
in our new house there are two Manual velux Windows.
I want to open/close both separately and mount at both shutters.
Windows are at different floors. I have Some doubt about what i need from velux to control it all with Homey (and remote in the room )
Hi guys!
I’ve been using the Velux community app of Peter Jansen (much appreciated Peter!) in combination with 6 Velux windows, blinds, sun screens and some room sensors.
I’ve been experiencing that my automations on a regular basis don’t seem to work because the app seems to loose some sort of connection/session with the active control hub. On a restart of the app in homey everything works fine again.
As a workaround I now imported a restart of the app at the start of the planned flows and that seems to solve my problem but I can’t figure out what is causing the real problem.
Do any of you recognise this behaviour?
Hi everyone,
I’m using the Homey Velux app together with a VELUX ACTIVE with NETATMO gateway (model code 3LG E01 EU).
This system connects VELUX products (windows, blinds, shutters) via io-homecontrol and communicates with the VELUX / Netatmo cloud through the gateway.
My setup worked perfectly for many months, but for a few weeks now (I believe since late 2025) my four shutters stopped responding in Homey.
What I observe
  • The devices appear online in Homey
  • When I try to control a shutter, the command times out
  • No “device unreachable” warning is shown
  • If I restart the Velux app in Homey, the shutters briefly show as offline, then come back online
  • After that they still timeout on every command
Interestingly, my indoor climate sensor still works and reports data regularly, so the gateway itself seems reachable.
What I already tried
  • Restarting the Velux app
  • Removing the Velux app from Homey completely
  • Installing the app again and trying to reconfigure everything from scratch
Unfortunately, the setup process also fails with a timeout when trying to add the shutter devices again.
Possible authentication change?
When I log out of the official VELUX ACTIVE app and log in again, I now have to authenticate via the gateway by pressing the button on the underside of the hub to retrieve an authentication key.
This step seems to be required for new devices or users and might be related to security changes in the Velux / Netatmo ecosystem.
My suspicion is that:
  • the gateway requires a new authentication
  • but the Homey Velux app does not trigger this authentication flow
Without completing this authentication step, the gateway might no longer allow control commands, which could explain the timeouts.
Questions
  • Has anyone else with VELUX ACTIVE with NETATMO experienced similar issues recently?
  • Could this be related to changes in Velux / Netatmo authentication or API behaviour?
  • Is there any workaround or updated version of the app that supports the newer authentication flow?
Any ideas would be greatly appreciated.
Thanks!
Just a quick update on my issue.
As a workaround I decided to try a different approach. I reset all shutter motors and paired them with my Somfy TaHoma bridge instead, since they use io-homecontrol.
The reset process was not exactly straightforward (each shutter motor had to be reset individually before it could be discovered again), but in the end it worked successfully.
After pairing them with TaHoma, I was able to integrate the shutters into Homey via the TaHoma integration, and control works normally again.
So the shutters themselves and the io-homecontrol communication appear to be working perfectly fine. The issue therefore seems to be specific to the VELUX / Netatmo gateway integration in Homey.
For now I have retired my VELUX bridge and put it aside, since the TaHoma setup is currently the only reliable way for me to control the shutters via Homey.
Does this only work with VELUX Active with Netatmo, or is the standard VELUX App Control gateway enough? I don’t really need the extra sensors that come with Netatmo.
Hi Peter,
My exterior awning blind (store pare-soleil) used to work with the Homey Velux app but is no longer found since a recent update. The roller shutter on the same gateway (3LG E01) still works fine. Could this be a regression?
Thanks
Hi - I read the first post about the limitation of not being able to close the Velux windows after opening them via this app. Does this limitation still apply, or has it been resolved in the meanwhile?
Hi, did we find a solution to bypass the code to open the Velux or to give the code to Velux through a script like it is done with Google Home?
Thanks
I’m experiencing the same problem with the Velux Kig 300 and the Velux App that always asks for the code to open the shutters, thus blocking the Homey App. It doesn’t seems to be a problem for the blinds though.
Is there the same problem with Tahoma?
Best regards,
Guillaume
First of all, thank you for your work on the VELUX app.
I have just installed a new VELUX KIX 300 gateway and connected it successfully to the official VELUX app. Everything works perfectly in the VELUX app, and I can both open and close my roof windows.
I then installed the Homey VELUX app (version 1.3.1). The app successfully imports all my devices (2 roof windows and 2 blinds), and it correctly displays their current positions.
However, I have an issue with the roof windows:
  • I can close the windows from Homey.
  • I cannot open them or move them to a partially open position.
  • When I try, Homey displays the following message:
“Due to Velux security measures, you can only view the status and close the window covering. Opening it is not permitted.”
This message appears even though I’m controlling a roof window, not a window covering. The same windows can be opened without any issues from the official VELUX app.
My setup:
  • Homey Pro (2023)
  • VELUX app v1.3.1
  • VELUX KIX 300 gateway
  • Official VELUX app working correctly
  • 2.4 GHz Wi-Fi (UniFi network)
Is this a known issue with the current API or the Homey app? If you need logs or if there is a beta version available, I’d be happy to help test.
Exactly the behavior I am experiencing right now. Did you manage to get it working?
