I’m new to homey, received my homey pro this weekend, I want to add my shutters, but they’re not visible in the homey app, but they are visible in the tuya app on my phone.
I already installed the tuya cloud app on homey and was able to add power plugs.
Via a scene I can run it via Homey.
Is it also possible to add the shutters as a device to homey?
Same goes for my wifi garage door openers. Works fine in Tuya (and Smart Life for that matter), but not able to add them in Homey. Am I doing something wrong, or are they simply not supported (yet)?
How do I now if it is (or can be) supported by API or not?
Not when they’re not shown as available device.
Search for “tap-to-run” and/or “raw commands” in the first post to control them anyways
(this is your answer as well @Supra25)
When I try to configure the app with only LEGACY API’s I can save the configuration.
But, when I try to add a device I get the message “Configure the App first”.
When I try to configure the app with LEGACY / OFFICIAL API (or OFFICIAL API ONLY)
I get the dreaded 2406; msg: skill id invalid error.
I’ve already tried to relink my account several times, also I’ve created a new cloud project, but nothing seems to work… Is there anyone who might be willing to help me?
(The 2 devices which I moved from the WOOX app to the TUYA app do show in http://eu.iot.tuya.com )
After the app was updated with the new API,
Did you at least once remove all Tuya cloud devices from Homey, and added them again in order to use the new API?
I have managed to add my wifi temperature sensor and receiving values on a created virtual device.
Now i have the problem the temparture is factor 10 of the normal temp. So it shows 250 degrees in stead of 25.0 degrees for example.
Any ideas how i can change that?
Looking in the forum I read people have had the same problem with a thermostat. If i understood it well they updated the app for that and should work well now. However I have the same problem with this temperature sensor. I cant find anywhere how to change it.
In the smart life app it shows the right value (25.0). But the tuya numeric value is a factor 10 highter.
I checked homey developers tool and Tuya IoT platform, but cant find a place where I can change it.
Hello, please i have Fairland pool heater linked to my smart life tuya app and would be happy to link it to homey too, could you please help me what i need to to for that? Thank you
Hi, I am new quite new with homey pro. I got the Tuya cloud app working with some lights and some sockets. Now I have a smart water controller from Hombli. Is there a way to add this device as well?
I have 2 different models of AC thermostats installed, the first one I added it manually to tuya app and in Homey it was discovered by taping on Aircondition, while the 2nd one was discovered automatically by tuya app (recognized as ac fan coil thermostat) but couldn’t be added by tapping on Aircondition in Homey, it was discovered after I tapped on water thermostat I guess (see below pic):
The issue is now there is a big difference in terms of controlling and setting up the temperature!
