@Jurgen_Heine and @Dikootje do you know what problem this is ?
i think i haven`t waited long enough. the unit self does what i needs to do. only up and down are no right for my modle is that something you can add to switch it?
Exellent work!
They work for me also the switch but up and down are upside down up is down and down is up
Sorry wrong discussion.
@Mark1541 and @Wesley_Witjes I will look if itâs possible to make a setting to turn arround those buttons. Otherwise I add a new device with those buttons turned arround. No ETA yet, just moved into new house, so time is limmeted.
Great thank you
Thank u!!
A new version is now on test. This version has a device setting to switch the buttons. I donât own a cover myself so I could not test it. Please let me know if itâs working. Otherwise send error report.
Tested right away works great!!
Great it works only thing I miss now in this version to set a mood. In the older previous version it works very well @Jurgen_Heine
Thank you now it works
Great work !!!
Hi fellow Homeys,
It has been asked before, but that has been a while. Is it still not possible with this app to add or change the color of a led strip connected to a Tuya led controller?
Thanks for your answers?
Regards,
Dennis
I guess you can change everything by calling upon (tap-to-run) automation tasksâŠ
Hi @Dennis_van_Dinter, sadly itâs still not possible. But you could use scenes in flows in combination with tap-to-run as @Hannes85 mentioned.
Thank you both!
Hi everyone,
I just added my device via the smart life app. It worked the first few minutes via Homey. Could switch it on and off.
When I just opened Homey (15 minutes later or so) I noticed an exclamation mark, pressing on the device it gives an error device temporary unavailable⊠Any ideas?
The plug still works via the smart life app. The plug is like 2 meters away from my WiFi mesh netwerkâŠ
I also tried to readd it⊠Same thing happend. Works for the first minutes then it stops
I am using the Deltaco SH-P01E but cannot get the energyreadings in Homey. it works in the Tuya app but the info is not transfered to Homey.
Could this be solved ? or have I done something wrong when setting the things up ?
Hello everybody,
My Tuya cloud app is frequently crashing for a few weeks now.
Are there more people with this problem?
