Yes, same here. restart app fixes it for a day but then it starts all over again. Can i revert to previous version or try a new beta to see if that impoves it?
I have to look at the unstable problem, please send crash report when you encounter it.
Hi Jurgen, i created a diagnostic report when in crashed state before restart app:
0dfbfe4c-b629-410e-ae24-8771551cdd4e
Also created one after a restart, app in working state:
eaada8ae-3cb4-4b6f-866b-2ea376b7e983
Hello Jurgen,
Here is mine.
02ee8f8b-3692-4e59-b6c9-e9cca1943f37
@runner780 and @Hugo, I have received the reports. There is a new version in test channel. I have added more logging and hopefully a fix for the crashes. If you still encounter the crashes, please create new crash reports.
Hi Jurgen,
installed the test version and gonna try it for some days. hope issues will be resolved now. Thanks for the speedy response. iâll keep you posted.
Me too!
Iâm sorry Jurgen,
Again, my app crashed.
Send you the crashreport.
decbf003-1546-485d-93c9-27792863f9ca
Received report, have to investigate further. Itâs strange and unexpected.
Same here Jurgen, with v0.0.9 installed.
after crash before restart: fb732237-7941-4f04-ba47-bef40d26e356
After restart (all ok) : 1c0ab99e-478e-4113-9add-e67baa2280db
There is a new version in test channel. In both crash reports, there is a strange error coming from the cloud API instead of a status message. This resulted in a crash, despite the error handling already in place. I changed the error handling and hopefully this fixes the crash. Itâs hard to find because my version is stable and Iâve never seen the error before. If you are still seeing the crashes, please create new crash reports.
Ok installed and testing.
Sorry Jurgen, still no succes. Report before restart app and after. 9e61b9d2-c34b-469a-9ae3-5b2dc14672c6 and 0552ddf9-c18a-427c-85a4-365eeb2536e9 hope youâll find a fix soon. All the effort is really appreciated.
Hi Jurgen_Heine. Thanks for the app. Are there any plans to add other devices from tuya smart app? I have a dehumidifier added and it would be perfect. ThanksâŠ
No problems after installing latest version yet.
@runner780, sorry to hear itâs not solved yet. I have to investigate why itâs still not working for you. In mean time, till I fix the error, I suggest make flows to restart the app after crash and if nessary schedule a restart every night.
@Hugo, good t hear itâs working for you now.
@Grigoris_GR, I have to look when I have more time to add more devices. At the moment still busy with my new home.
Hi, i installed the tuya cloud app and also configured it. But i can t find my light via add device (tuya cloud). In the smart life app i can see and control the light. I created a diagnostic print (889363cd-7057-4055-aa74-db6afacfa5c3) may you can have a quick look. (Btw i insalled also the experimental Version but still i can t find my lights) Thanks and BR from Germany
@Martin_Tschanun, according log, you should have received an error message that credentials are not correct.
Hi, there is no message about wrong credentials. Also I changed the password on smart life to a weak one but this is also not working. I Uninstaller it and installed it again. Still the same, 6c84d75a-f125-438c-8373-afd0449013e3
About country code is +49 correct?
Strong passwords should work, I have one myself. Country code 49 is germany and should be correct. But I have succeeded loginâs with other countrycodes then the one I registrerd with. But Just to be sure I advise to set code correct. Below is the log. The JSON( line with brackets) message is direct response Tuya. So according log you are using incorrect credentials. If you use Smart Life app, you must select Smart Life as Business. If you are using Tuya app then you have to select Tuya for Business.
---- stdout ----
2020-11-08 18:43:17 [log] [TuyaCloudApp] Tuya cloud App has been initialized
2020-11-08 18:43:17 [log] [TuyaCloudApp] undefined
2020-11-08 18:43:17 [log] [ManagerDrivers] [light] Tuya Light Driver has been initialized
2020-11-08 18:43:17 [log] [ManagerDrivers] [switch] Tuya Switch Driver has been initialized
2020-11-08 18:43:17 [log] [ManagerDrivers] [cover] Tuya Cover Driver has been initialized
2020-11-08 18:43:52 [log] [TuyaCloudApp] Start connection to cloud.
Discover devices
{âresponseStatusâ:âerrorâ,âerrorMsgâ:âGet accesstoken failed. Username or password error!â}
---- stderr ----
