My bad! It was a flow actually… Never thought about it anymore haha. Probably in the beginning testing something. It never worked for some reason, until recently became active.
Deleted the flow now, all sorted. Many thanks, it was indeed a flow based on Tuya Cloud when a text is received…
I’m using a LSC (tuya based) camera with pan and tilt, would someone know if it is possible to add the camera and at least read out the movement detecting OR even better pan/tilt movement by homey?
As for now it’s not possible to add a camera in this app but would be great if there a decent work around
Hi, sorry for probably silly question, is a wall mounted thermostat (controls radiators and floor heating) falls into „thermostat” category of tuya devices which can be installed on homey using tuya app? I am completely new to homey so please do excuse me if this question has already been asked… I attach a picture of the device I am writing about…
Yes. Just try adding the thermostat with any of the 4 different device types to see if it gets recognised. Start with ‘Thermostat’. Nothing’s gonna break.
I am almost the happiest person, because I got my watering valves up and running… but: although I have set a mining duration in the tuya app and I am calling the device over could with command switch = true and - just tried that - also set the work_state to manual (tried to call is before and after the switch command) => watering is only down to 10 minutes (countdown is reported via the listening flow I implemented)…
This is my watering flow that runs for 10 minutes:
What I am trying to achieve is that a cronjobb checks for weather (rain) and if precipitation is < 2mm watering is performed 3/day for 30 minutes… Everything works except for the 30 minutes…
For “for 30 minutes” delays you could use Chronograph for example.
Don’t use the ‘onboard’ delays for not-very-short delays, because they don’t survive a reboot
When Homey powers down or restarts during the running delays, they don’t run anymore and therefore the flowcard “watering turn off” never turns the water off.
Chronograph timers survive reboots.
Create double or triple checks to see if the watering actually has turned off.
You don’t want floods
Anybody has solved this issue or is it just range interpretation e.g. 1 deg in homey represents 1/2 deg of the thermostat range?
TIA for your kind help.
Best, J.
EDIT: 1 deg in homey is 5 deg in thermostat… this makes usage very difficult. Maybe anybody has some solution to make the increment lower (either in homey or on device)…? Thanks. J.
Hi Peter, your pet ignoramus here!
I was trying to submit a Tuya device and was pointed to github, whichdidn’t seem to have a clear place to record the item I’m interested in. It also seem to be pointed to Homey CLI, but I don’t have a clue what that means! Could you explain please?
My second problem is connected to the wifi disaster I had recently. All my tuya blind control buttons have lost connection to my wifi hub, and that it after over a year of faultless use. I cannot find a way of reconnecting the devices. Is there a way through the Tuya app, I’ve spent ages trying but there doesn’t seem to be a way of reconnecting.
Julian
