Sometimes you need to restart the Homey Tuya cloud app and the add a device based on the Homey Tuya cloud app.
I think it is re retrieving the devices from Tuya cloud after restart
Itâs just not supported to use as device:
https://homey.app/nl-nl/app/com.tuya.cloud/Tuya-cloud/test/
To connect it with Homey, pls read the first post and look for the âRAW commandsâ howto. Itâs a little more effort, but it works fine.
Thx; I started to make an adv. flow in homey pro 23; The Tuya cloud card shows 3 tags: Apparaat id, Functienaam, Functiewaarde. For some reason these tags are not available in e.g., the âDANâ cards.
In the standard flow I was able to send the 3 tags to Whatâs app.
Is there a difference in Std flow and Adv flow?
Hi, you have to have the cards connected to eachother by drawing lines, after that, the 3 tags become available to other cards like the Then (âDanâ) cards you like.
Xmpl:
Ha, the basics.
Interestingly, there are also tags available for cards that are not connected.
Another Tuya question:
Currently, I have an hourly update of , e.g., temperature.
Is there a command to get temperature on request?
Is there a more frequent way of getting updates?
Hey @Harry_Inia - as far as I know there are three ways to get an update sooner from these devices
- Recycle power (force update)
- When the value deviates from the previous value measured by more then 5% (i think - would have to look up exact value) - it generates an update (by measurement)
and this also brings us to the last way to force update - hold your hand around the device and warm it up - but generally speaking youâll be the quickest by just rebooting the sensor.
Cheers,
Vince
Hello everyone,
first of all thank you for your work.
I have an error that appears when I try a Tuya scene
Cannot read properties of undefined (reading âmapâ)
Could you help me ?
Thanks
Thx Vince!
Is there a way to make a device icon and have the Temp & humidity sensor visible as a regular device on the dashboard?
Did you get it fixed? Having the same problem
Yes, look for the âRaw commandsâ howto at the first post of this topic.
The more I read Post 1, the more I findâŠ
Post 1 is the gift that keeps on giving that- and the patient reminders of @Peter_Kawa that really- you should read post 1. Went through the learning curve myself as well
Thx Vincent, and additionally, itâs the same system for many other app topics as well.
I think I will read it again
The Tuya temperature comes in as, e.g., 200 i.s.o. 20,0. I thought to do a quick divide by 10, but that is not that straightforward to do calculations.
Any quick hints?
In the advanced virtual device you mean? Pls provide usable info, itâs complicated as it is already
It is that simpleâŠ; thx!
Hye, can annybody help? i bought a qnect contact senor.
My tuya clud en evrything is conected, i dont get anny errors but homey cant find it. anyboddy that canb help me?
Is it connected to your tuya hub? Is the product suported on the app on homey?
no hub it via wifi but its conected to the tuya app.
It should be its an door/window sensor
