[APP][Pro][TEST] Vestel EVC04 & Webasto Unite
Homey app for the Vestel EVC04 and the Webasto Unite. The Unite is built on the EVC04 and uses the same Modbus interface. The app talks to the charger locally over Modbus TCP, with no cloud involved, and is meant for Homey Pro.
It works on my own Vestel EVC04 (firmware v3.187.42). Now I’m looking for someone with a Webasto Unite to test it. Other EVC04 owners are welcome too, of course.
Installing
Install the test version from this link:
:backhand_index_pointing_right: Vestel EVC04 & Webasto Unite | Homey
Then add your charger through + → Add device → Vestel EVC04 & Webasto Unite → choose Vestel EVC04 or Webasto Unite, and enter your charger’s IP address (port 502, unit ID 255).
Requirements
  • Homey Pro (2019 or 2023)
  • Modbus TCP enabled on the charger and a fixed IP address
  • No other Modbus integration talking to the charger, since it only accepts one connection at a time. If you already use another Modbus app for your charger, turn it off.
  • For 1/3-phase switching: firmware 3.187.0 or newer
  • For solar charging and load balancing: a P1 meter in Homey
Features
Monitoring
  • Charging state: unplugged, plugged in, charging or paused
  • Power, total kWh meter (shows up in Homey Energy), session energy and duration
  • Current and voltage per phase, and the number of active phases
  • Picks up the maximum current the installer configured in the charger
Control
  • Charging on/off and max charging current (6–32 A, never above the charger’s own maximum)
  • Charge modes:
    • Fast: always charge at your max charging current
    • Minimum + solar: always at least 6 A, faster when there is solar surplus
    • Solar only: charge only on solar surplus, with a start and stop delay to ride out clouds
    • Off: charging paused
  • 1/3-phase switching: switches to 1 phase automatically when solar surplus is low, so charging can start from about 1.4 kW instead of 4.1 kW. Charging pauses briefly while switching.
  • Load balancing: monitors the current per phase of your whole house and lowers the charging current when a phase gets close to your main fuse. It pauses charging if less than 6 A is left, and ramps back up on its own.
  • “Limited by” shows why the charger is charging the way it is (solar, load balancing, your maximum…)
  • Triggers: car connected, car disconnected (with session kWh and duration), charge mode changed
  • Conditions: car is connected, charge mode is…
  • Actions: set charge mode, set max charging current, set phase switching, update grid measurement
Solar charging and load balancing
The app gets your P1 meter data through a flow:
When P1 meter → The power changed
Then Charger → Update grid measurement (power and current L1/L2/L3 from your P1 meter)
Then enable load balancing in the device settings and set your main fuse per phase, with a bit of margin (for example 23 A on a 3×25 A connection).
Without this flow, Minimum + solar charges at 6 A all the time and Solar only won’t charge. If grid data stops coming in, load balancing falls back to 6 A for safety.
Tested on the Vestel EVC04
:white_check_mark: Pairing and monitoring
:white_check_mark: Changing the charging current (16 → 8 A)
:white_check_mark: Pausing and resuming
:white_check_mark: 1/3-phase switching while charging
:white_check_mark: Unplugging the car
:black_square_button: Solar charging and load balancing are built in, but not yet tested in practice
What I’d like to hear from testers
  • Does pairing work?
  • Are the values right: power, kWh, current per phase?
  • Does starting, stopping and changing the charging current work?
  • Which charger do you have (EVC04 or Unite), and which firmware version?
If something doesn’t work, please send a diagnostic report: in the Homey app go to Settings → Apps → Vestel EVC04 & Webasto Unite → Report a problem, and mention the report ID here.
Questions, problems or ideas can go in this topic, or as an Issue on GitHub:
This is a community app and is not made by Vestel or Webasto.
