[APP][Pro] V2C Wallbox
V2C Wallbox
Control your V2C Wallbox charger directly from Homey.
NOTE
This app requires that Homey and the V2C Wallbox are connected to the same local network. The app communicates with the charger using HTTP commands based on V2C’s official specifications. For proper functionality, it is also necessary to assign a static IP address to the Wallbox on your Wi-Fi router.
IMPORTANT: For real house consumption data, solar production, and dynamic power management features, your V2C Wallbox must be properly connected to your electrical installation using measuring clamps or directly to your solar inverter, and dynamic mode must be enabled. Without these connections, these advanced features will not provide accurate data.
Specification Document
Useful links
Usage
  • Install this app on your Homey.
  • Ensure both Homey and the V2C Wallbox are on the same local network.
  • Add your V2C Wallbox device through the app.
  • Control and monitor your charger using Homey’s intuitive interface.
Current features:
Live:
  • Comprehensive charger monitoring:
    • Real-time charging status
    • Power consumption (watts)
    • Charging current (amperes)
    • Monthly and yearly energy statistics
    • House power consumption (requires measuring clamps installation)
    • Solar (FV) power production (requires connection to inverter)
    • Battery power status (requires system with battery)
    • Voltage installation
    • Signal strength
    • Firmware version
  • Advanced control capabilities:
    • Pause/Resume charging
    • Lock/Unlock charger
    • Set charging intensity (6-32A)
    • Dynamic power management (requires measuring clamps)
    • Timer control
    • Multiple power modes (FV Exclusive, FV+Min Power, Grid+FV)
  • Flow support:
    • Triggers for car connection/disconnection
    • Charging state changes
    • Error monitoring
    • Connection state changes
    • Power threshold conditions
    • Charging status conditions
    • Various control actions
  • Dashboard Widget:
    • Live status monitoring
    • Real-time power display (kW)
    • Energy consumption (kWh)
    • Quick pause/resume control
    • Dark/light theme support
Settings:
  • Configurable update interval
  • Adjustable min/max charging intensity
  • Dynamic power mode selection
  • Debug logging options
Test:
Currently nothing more than production
Tested Devices:
  • V2C Trydan Wallbox
  • Should be compatible with other V2C models due to unified specifications
Supported Languages:
  • :uk: English
Contributions
If you appreciate this app, consider supporting future development.
Contribute
This app enables seamless integration of V2C Wallbox chargers with Homey, enhancing your smart home setup with automated charging control and detailed status monitoring.
Script is outdated - i have added this translation W to Amp to a flow card
You might find a Homey Script useful that converts watts to amps. With this and the SET intensity card, you can subsequently control the charging based on the surplus energy from your PV system. This script calculates the three-phase power at 230V voltage referenced to neutral.
// Function to convert Watts to Amps in a three-phase system with a phase voltage of 230V
function convertWattsToAmps(powerWatts) {
    const voltage = 230; // Phase voltage (V)
    const powerFactor = 1; // Power factor (cos φ), assumed to be 1
    // If the input value is negative, return 0
    if (powerWatts < 0) {
        return 0;
    // Calculation of current in Amps in a three-phase system (for total power distributed across three phases)
    const currentAmps = powerWatts / (3 * voltage * powerFactor);
    return currentAmps;
// Capture the value from arguments (args) and round it to the nearest whole number
const power = Math.round(args[0]); // Assume the power value in watts will be the first argument
// Constant power value for potential supplementation from the grid (in Watts)
const additionalPower = 1000;
// Use the value for calculation
let current = convertWattsToAmps(power);
// Check if the current is less than 6 A
if (current < 6) {
    // Add the constant value to the power and recalculate the current
    current = convertWattsToAmps(power + additionalPower);
// Round the result down to the nearest whole number
current = Math.round(current);
// Save the rounded result into a variable using the new API
tag("currentInAmpsPrimary", current);
// Output to console (for debugging)
console.log(`The current is ${current} A`);
This script will help you manage the charging based on the energy surplus from your PV system by converting power in watts to current in amps for a three-phase system with 230V.
Apps which I use for controlling my wallbox
Simple Sys Log
Insight Trends Reloaded
First, I calculate the current average overflow from my photovoltaic system (PVE) over the last 1 minute. This allows me to filter out short-term fluctuations, such as when a cloud passes over the sun.
Next, I control the flow for starting/pausing charging and possibly adjusting the current in Amps. The flow could probably be simplified :). At a minimum, by setting the current to 0 Amps in case of a pause. However, I haven’t tried that yet.
Sys Log is used for back control of values which goes to homey script (above), and which are output of that script.
Hi! I have a V2C PRO charger but it’s not in the same Homey network. There’s not wifi coverage in my garage but it’s connected via 5G SIM.
Any change to use this Homey app with my charger?
Thank you for your help!
Hi, current integration is only via local HTTP API, so there has to be same wifi network? How about using some of TP-Link powerline adapters to create coverage via electrical wires?
Hello
I’m using the tp link PG2400 kit, and it’s working perfectly .
