[APP][Pro] Ratio Electric Charger
I built a Homey app for the Ratio Electric EV chargers.
What the app does
Pair with your Ratio app email and password, then see from Homey:
  • Charging power, status and mode
  • Which vehicle is connected
  • Energy charged today and in total*
  • Firmware information
  • Errors
  • WiFi/Ethernet connectivity
* The charger itself doesn’t keep a running kWh counter, so the “charged today” and “total” values are estimated from power readings, and can be slightly inaccurate after a brief interruption in the connection to Ratio’s cloud.
From Homey (or through Flows) you can start or stop charging, change the charging mode, and optionally set a maximum charging current (Basic mode only). Flow cards let you read or set the charging mode, assign a specific vehicle to your charge, and react to charging being blocked, your power being reduced by the grid operator, or a firmware update becoming available. There is also a dashboard widget that shows charging status at a glance.
Feedback, bugs and suggestions are welcome here in this topic.
Disclaimer
Unofficial, not affiliated with Ratio Electric. Built on aioratio, an async Python client for the Ratio EV Charging cloud API, which is itself unofficial too. Use at your own risk.
The app is now live in the Homey App Store! :tada:
A new test version (1.1.0) is ready.
What has changed:
  • The dashboard widget can now start/stop charging and switch the charging mode directly.
  • Vehicle-related wording is more consistent across Flow cards and the widget.
Want to help test it? Install the test version here:
Feedback? Let me know here.
