Wanted to let you know that i am getting Bad Request error when trying to turn off charging. And the data from the charger does not seem to update. Worked when i first installed it yesterday for starting charging. But stopped working today.
Otherwise really interested in this! Would you consider adding the ability to lock / unlock the cable to the app?
Hi and thanks for this app. I have an issue thow that I wonder if anyone else is experiencing. When I start and stop the charging via this app, manually, it works every time I’ve tried. But when I schedule charging, it sometimes works and sometime fails. When I check the log on the charger, I see that when it works, the schedule starts the charging, stops it and the start again. When it doesn’t work, it starts it and then stop, without starting again like the case when it works.
I don’t understand why it does that sequence of stopping and starting.
No, I only schedule and it does that. See the screenshot. The yellow is one sequence, when I just created a simple flow that it should start charge at 02:00. You see that it starts and then stops. The red is also one sequence when I pushed in the app on homey, that it should start charge. You see that that single command generated a start, stop and the start again. The scheduled didn’t charge, but the manual one did.
