[APP][Pro] Tasmota MQTT
You can set it higher via Tasmota.
https://tasmota.github.io/docs/Peripherals/#update-interval
312d7bfa-ab76-4202-9f56-a286d30a08e2
Sorry for the big delay.
Here is the report for not working tasmota device
Best regards
Did you find a solution for this?
Any luck finding an answer?
@spkesDE , isn’t it because of these errors (running existing instance via CLI) ?
2024-02-18T09:28:24.415Z [log] [ManagerDrivers] [Driver:tasmota_mqtt] [Device:1249f68e-6a25-4893-8889-5d9dccb1afa7] sensorTrigger is undefined
2024-02-18T09:28:24.416Z [log] [ManagerDrivers] [Driver:tasmota_mqtt] [Device:7feb8d12-50c8-421f-98bc-b65cb196ee45] sensorTrigger is undefined
2024-02-18T09:28:24.417Z [log] [ManagerDrivers] [Driver:tasmota_mqtt] [Device:9f797077-5212-4e25-8224-3057c38314c4] sensorTrigger is undefined
2024-02-18T09:28:24.674Z [log] [TasmotaMqttApp] Unhandled Rejection at: Promise Promise {
  <rejected> TypeError: Cannot read properties of undefined (reading 'trigger')
      at TasmotaDevice.checkSensorCapability (/app/drivers/tasmota_mqtt/device.js:491:38)
      at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
} reason: TypeError: Cannot read properties of undefined (reading 'trigger')
2024-02-18T09:28:24.676Z [log] [TasmotaMqttApp] Unhandled Rejection at: Promise Promise {
2024-02-18T09:28:24.677Z [log] [TasmotaMqttApp] Unhandled Rejection at: Promise Promise {
unhandledRejection:
unhandledRejection:
unhandledRejection:
As it’s loading the drivers dynamically, it’s something out of my reach/capabilities but maybe it would provide you some insights ? :wink:
it won’t create the this.sensorTrigger flow object since in the devices settings additional_sensors is false
See line 13, 35-39. This app is so messy in its writing. As we talked already on slack. I would to rewrite this app to make it more understandably for me. As of right now I’m not sure why settings.additional_sensors isn’t populated by the pairing process. MQTT is still a big riddle to me.
Also why the pairing keeps on loading and won’t show any devices is properly the fact that the app didnt registered any new MQTT events in this time and therefore no devices are shown.
On my local system using Tasmota Wall Plugs the pairing is working fine.
Whenever I try to add a device it prompts “No new devices found”. This happens when I try to add a new device and when I toggle the device on/off during the scan.
If i don’t toggle the device, it prompts that no MQTT messages were seen during the scan.
Does this mean that the device I am trying to add it somehow known? How can I add this device now?
Debug log 32a411f0-ed3d-423a-aef4-bed0eff7c055
Do you have the default group and topic?
That was it. The topic was correct, however it seems that the groupname was not default.
It worked right away after resetting the configuration.
Hi there. I’m using the Tasmota app for Homey to control 4 Sonoff devices flashed with Tasmota. Works great apart from the fact that for some reason the devices sometimes become listed as unreachable. My workaround is to restart the app, after which all is fine again. I have no real clue as to when this happens, it seems quite random but it always takes a while. Running this on a Homey Pro 2023. Is this any known issue?
I’ve created a flow to restart the app every night but that’s a rather ugly workaround I’d rather get rid of.
Have you shared diag. log by any chance ? But I don’t have this problem, only that the signal strength is not getting updating after while…
Not yet, no. I’ll stop the daily restart flow for now and wait until it happens again and then I’ll share the diagnostics :+1:t2:
I’ve had the same problem for a long time now, but I can’t understand the reason, as you say, it’s quite random, if there is a solution to this I’d be happy. I restarted the app this morning due to this problem, as soon as it happens again I will share the logs
The problem with this app is that the backend is quite a mess. In my opinion, it would require a complete rewrite to ensure flawless performance. However, this is a significant task that would necessitate a larger MQTT network, which I simply don’t have. Additionally, it would demand a lot of time—something I lack in my day-to-day life.
Also I don‘t know the issue/cause of the crashing.
In the meantime I’ve switched to using the MQTT device powered by the MQTT hub app. It’s a bit early to tell but for now all seems well. This eliminated my use for the Tasmota app so I ended up removing it.
Thank you for letting us know, I just wonder what is the memory requirement of MQTT HUB vs. Tasmota, I guess it’s more then Double ?
Hi, I discovered that the main problem occurs when homey is restarted, once it is turned back on all the devices are unavailable by restarting the app the problem is solved. I attach the code of the report made in the app: d80bb917-
d32d-4cd3-9bc4-e0e7cc9a0be1
Since yesterday or the day before, i have a problem with tasmota plugs in flows.
If in turn a device on by hand (in app by pressing the button) all works fine. If i use a Flow like
if "huemotion detects a motion" then "turn tasmota plug on"
the plug does nothing. Other, like zigbee2mqtt apps are working fine.
Appversion v0.13.2
I have create a report:
41a77c44-4dc2-4374-a878-3241232bce76
Please try the latest test version.
no change, the same like before.
c88f4578-4b09-493d-bdc5-df901314115a
Thank you
