[APP][Pro] Synology
Yes that’s correct. Because it’s local only. It’s possible to use it with SSL but it requires a certificate…
I suggest to use port 5000 and a local IP. In this way you can also benefit from the Wake-On-Lan function
Ah, but I do want SSL for external connections, but it’s not possible to turn off SSL for LAN-connections only right?
I do have a SSL-certificate and I am using a different port (which I entered in the Homey-configuration). I still get the message: Could not find that PairSession.
Will enable the SSl setting. Then IT should be possible to connect via SSl. :slight_smile:
Let you know once the update is there
New app update (test: 1.5.1.):
  • ADD: SSL option for pairing
  • ADD: SSL option to device settings.
@Crashy
Thanks, working instantly!
New app update (test: 1.6.3.):
  • FIX: Remove redundant dependency
  • NEW: add hashed passwords (hide in homey developer tools)
  • FIX: new secret key for password encryption
@Rens_Hoekema
Thx @martijnpoppen for the fix :smiley:
@martijnpoppen would it be possible to add an action card for changing the fan speed mode via flow?
@DirkG it’s on my to-do list :wink:
New app update (live: 1.6.3.):
Hello Martin
I have the DS 220+ running…tried the app… it says “invalid_setting_type”…everything looks fine for me :slight_smile:
What could be the problem??
Hey @Till ,
Can you send me a diagnostic report? Then i’ll take a look if I can find something.
More → Apps → Synology → Settings wheel right top → diagnostic report
Thanks!
New app update (live: 1.6.5.):
  • FIX: invalid_setting_type bug
CC: @Till
Note:
When you don’t get updates you might need to fill in your password again. something went wrong with new devices since yesterday : )
Would it be possible to print the uptime in days hours?
Hard for me to divide by 24 by head :joy:
@Martijn_Hoogenbosch yep Will add that :sweat_smile:
New app update (test: 1.6.6.):
  • ADD: days/hours/minutes for uptime
Love this
I’m getting this error: Invalid IV length. I did change my Synology password (and changed it in Homey as well).
@Crashy Can you send a report? Then i’ll check whats wrong
I just turned on Debug in the Synology NAS in Homey, how can I send this?
