Is the Homey user member of the Administrators group on your NAS?
Can you actually access your NAS via HTTP? So if you open a webbrowser and browse to the indicated IP and port, can you access you NAS? Or does it automatically switch to a HTTPS connection (with SSL) and a different port.
@Dre_Vlag why are you sending a Flowchecker report? I donât see how thatâs related to this issue?
About the report. Make sure to remove character like ? or & from your password.
The API connects via a url and canât use these character in a proper way, they will go bad when encoding the password.
@martijnpoppen
I had this ? in my password. I have now changed my password to only letters and numbers.
i have try it again but still the same time out
@Dre_Vlag youâre using different IPâs I see
Make sure it use the same credentials and ip and port which you would use to access DSM
Also make sure homey and synology are in the same local network
