[APP][Pro] Synology
@Iljas_Mahieu it was just my guess i dont know where you can set this in the top of my head. Have to search as well :wink:
Will check tomorrow :slight_smile:
ok thx, i search everywhere but cant find it :slight_smile:
@Iljas_Mahieu its something with blocked ips. As said i’ll check tomorrow…im not home at the moment
Did you find something, because i cant find nothing
@Iljas_Mahieu yes:
DSM 6: Control Panel - Security - Account - Allow/Block list
DSM 7: Control Panel - Security - Protection - Allow/Block list
to bad, thats not the solution
@Iljas_Mahieu ok, then i dont know. Only thing i saw is that your Synology is blocking the API calls. So its something on your NAS :confused:
i’m wondering how to use the hashed in the tag.
I am trying to upload snapshots and add a date-time stamp to the filename but cant find out how to do so.
Thanks for the help
@Stephan sorry i have no idea what you mean. What is it you’re trying to do?
i would like to upload snapshots to the NAS (works now already) but change the filename (currently a long name like “aad540762108c6534b5fddda5f03eab213036c38” ) to the currect date-time like:
2023-12-19/20:28.JPG or something simular.
I have no clue what the hashed option does, other then that it creates a new file instead of overwriting the currect one.
@Stephan currently not possible. It just creates a new file. This would require a change in the uploading mechanism
thanks for the quick answer
New app update (:orange_square: TEST: 1.10.3.):
  • FIX: some cards had wrong type, causing issue in Homey-Core
@Sharkys FYI :point_up:
Thanks for the great app! It works great, my Synology DS214Play is connected, the only thing not working is the start by using wake on LAN.
I can wakeup my Synology using the DS Finder app, but nothing happens when I use the flow card.
Any ideas?
@neoscaler did you enable WOL in your DSM?
See FAQ Q3
Thanks for he hint with the MAC adress. I did not enter it there, I suppose it will work then.
@neoscaler the API doesn’t always return the mac address. If you can fill it in manually it should work
