[APP][Pro] Surveillance Station 2
Adds support for camera’s available in Synology Surveillance Station
App store : Synology Surveillance Station 2 | Homey
Features
  • Native homey camera support
  • Supports all camera’s available in Surveillance Station
Camera
Motion detection
  • Enable/disable motion detection when installing device and in advanced camera settings
  • Motion detection pushed by Surveillance Station
Flows
  • Action to update camera image. This can be used in doorbell flows
  • Actions for recording (start / stop)
Home Mode
  • Manage your Home Mode by adding your Surveillance Station to Homey
Flows
  • Actions to manage the Home Mode
  • Triggers for Home Mode (enabled / disabled)
Getting Started
  1. Install the app
  2. Add the Surveillance Station as a device
  3. Add the camera(s) as a device
  4. Done!
Reconnect/Repair your device
  • Go to the devices settings, choose “Maintenance actions” and then “Repair”.
Tested with
  • DSM 6.2.2-24922 Update 4
  • Surveillance Station 8.2.6-6009
  • Homey 3.2.0+
Troubleshooting
  • Problem: When your Synology reboots, the connection is lost with your device.
  • Solution: Go to the devices settings, choose “Maintenance actions” and then “Repair”.
Note
  • This app is not officially maintained by Synology.
3.3.*
  • Create snapshot flow action added
3.2.*
  • SDK 3 + Bugfixes
3.0.1
  • Credentials moved to Surveillance Station with option to save credentials for auto reconnect. Please note that a Surveillance Station is required as device to add before you can add camera’s.
2.3.0
  • Added flow triggers for Home Mode, renamed Home Mode states to enabled and disabled
@Dijker can you merge this into [APP][Pro] Synology Surveillance Station 2 ?
Thanks! :smiley:
