[APP][Pro] Synology Surveillance Station 2
Synology Surveillance Station 2 - Adds support for camera’s
NOTE
This is not the topic for Synology Diskstation
The topic for Synology Diskstation you can find here: Synology
Useful links
Current features:
  • Native homey camera support
  • Supports all camera’s available in Surveillance Station
Camera:
  • Motion detection
    – Enable/disable motion detection when installing device and in advanced camera settings
    – Motion detection pushed by Surveillance Station
  • Flows
    – Action to update camera image. This can be used in doorbell flows
    – Actions for recording (start / stop)
Surveillance Station:
  • Home Mode
    – Manage your Home Mode by adding your Surveillance Station to Homey
  • Flows
    – Actions to manage the Home Mode
    – Triggers for Home Mode (enabled / disabled)
Supported Languages:
  • :uk: English
  • :netherlands: Dutch
Contributions
If you appreciate this app, contribute to future development by making a paypal contribution
or buy me a coffee on Ko-Fi or Bunq.me
image ko-fiimage
:laptop: Apps made by @martijnpoppen
See for more apps link below :backhand_index_pointing_down:t2: or just open the pull down.
Placeholder 1
Placeholder 2
Frequently Asked Questions
Q1: Reconnect/Repair your device
A1. Go to the devices settings, choose “Maintenance actions” and then “Repair”.
Q2: When your Synology reboots, the connection is lost with your device.
Q3 When the connection is not working make sure to check the following
According to the release notes of Surveillance station: 9.2.0-11289 theres a change in user roles.
  • Inside Synology surveillance station
  • Go to User
  • Check if the user (which you use in Homey) has administrator priviliges. This is a requirement to use it with Homey.
As mentioned in the patch notes:
5.: Added support for a new default privilege profile named “Administrator” that grants users access to all objects and the ability to manage Surveillance Station settings. Certain actions that involve modifying DSM settings are restricted and require the user to be added to the DSM administrators group.
12.: Offering a streamlined interface by hiding the Map and Snapshot application from the main menu and desktop for users without view privileges.
Nice app, thanks a lot!
It works well (almost). Very pleased I can take snapshots and push them throw notifications as the old Surveillance app would fail after first screenshot.
The one part I have problems with is that the motion alarm gets stuck on Yes. Although it has been acknowledged to be turned off on the next page.
See here:
But all good in here:
Homey firmware 4.2.0
Thanks and let me know if more details required.
EDIT: restarted Homey and now all looks OK. Weird in first instance anyway.
Hi @danone,
Strange thing. Not sure if something is wrong with the Synology app or with the Homey app. Please let me know if it happens again.
Update 2.2.1 is live!
  1. In this version I have fixes some pairing issues (layout an security)
  2. You can now start or stop recording via a flow action
Update 2.3.0 is live!
  1. In this version I have added flow triggers for changes in Home Mode
  2. Home Mode states are now renamed to “enabled” and “disabled”
Thanks for a great app. I recently updated to Surveillance Station version 8.2.8-6335 and I have some issues with my cameras now. I constantly get the red warning symbol on my cameras, when I try to repair it seems to work at first, but as soon as I get back to the camera screen I get error messages again. Someone experienced this?
Screenshots are hard to retrieve since the error message disappears quickly.
Hi @Exile82,
The only thing I can think of right now is when the storage is full on your NAS/Surveillance Station or Homey’s storage. The reason you need storage is to store a token on both sides to communicate and to save the camera image. Could you please check if you have sufficient free space?
Thanks for your response! Of course, on my NAS I have 1.28 Tb of free space and the Homey says storage is fine.
The app says that connection is expired. After repairing it says that it was successfully done:
but the app immediately says that connection expired
Strange, I am running the same version as you do without any problems.
Can you check your Logs in the Log Center (Main menu on your Synology).
Maybe the logs tells us something…
Hi! Well, there are a nunch of things there, like people constantly trying to hack my Synology. :slightly_smiling_face:
But nothing that seems incorrect with Surveillance Station.
What version of SS do you run?
I run these versions
  • SS version 8.2.8-6335
  • DSM version 6.2.3-25426 Update 2
  • Homey version 4.2.0
Do you connect with your SS via ip address or hostname?
Just checked SS again, seems that there are some issues with the camera itself, actually. I am gonna check that first and see if that resolves the issue. Thanks
I am trying to connect my surveillance station but i get this error message “error: could not find that pairsession”
What could be the problem?
Kind regards, Michiel
This happens when you switch between the Homey app and another app on your phone.
Thankyou for your response, still no luck. Nou it says timed out. What port do i need te fill in? I now fill in 5001 for https and portforward it in my router.
http and fill in port 5000, no need to open any port in your router if the NAS and Homey are in the same network with same subnet.
And yes, do not switch apps, copy paste the password before you start the process.
Thank you for your response! And what if my homey and NAS are not in the same subnet ( i have an IoT network where homey is). I tried port 5000 for http but that did not work. Do i need to open more ports?
