[APP][Pro] Support for Fronius inverters and smart meters
Is there a new app for controling or setting values for the storage?
Or is the intention to use the modbus app which has been discussed here.
The modbus app is a little complicated and not sure how it should be setup.
It fails with connect errors complaining of slave device.
Is there an easy howto or a picture so we can see the ide’s to use and which adresses.
Thanky for a good forum but I’m new and just getting started.
2 x Gen20 10kW (master and slave)
Smartmeter
1 BYD HVS battery
The modbus app thread includes some examples:
[APP][Pro] Modbus
And my page has some blog posts for Fronius specific settings.
https://rwdevelopment.de/homeypro-apps/modbus/
Modbus: Anwendungsbeispiel – Ronny Winkler
For further questions about Modbus, please use the thread linked above.
can somone help me i need a flow for ongrid. like when injects a custom amount of energy on network to turn on a device or off.
Hi. in solarweb i can se my load. (what my house consume) but in homey i cant. What i can se all the other values are correct. like grid power, akku power and pv power. for example my house consumes 989W but loadpower says -55 watt.
How do i get the correct load?
Just to let you know the local Fronius website can be integrated into Homey Dashboard.
Thanks. But i want the same value for my house load in Homey that you can see in solarweb. I can find the loadpower in Homey but that value is not correct.
Hi ; could you please open an issue on github ? (Issues · ThomasHoussin/com.thomashoussin.fronius · GitHub)
Could you please post in this issue the result of http://<your_ip>/solar_api/v1/GetMeterRealtimeData.cgi?Scope=System and the values that you see in Homey ? Thanks
Have you ever found a solution to this? Otherwise I have to check the modbus docs again. Best, Ek
I have the same issue
Hi i cant add fronius storage or get updated values on my installed smartmeter
Anyone having any luck with leveraging the Fronius app with new Homey Energy feature? Not really working for me as of yet (contemplating PBTH or Custom HA device). Fronius & Tesla Issues with Homey Energy. It would be great if this just worked OOTB with the Fronius app.
Is the new Reserva battery from Fronius supported by the app?
Does somebody have this battery in use already and is it working with Homey Pro? I am hoping to buy it together with solar panels and the Fronius SYMO GEN24 plus inverter.
I cannot find it in the supported list, but maybe it works, as it is the same brand.
Thanks!
Jag undrar kommer du lägga till billaddaren i appen?
