I have reported this as an issue with the library. Not sure why but I have the same in Arnhem. Not really an issue for me as it is not that critical
Still getting some strange results on flowcard checks (now on test version 1.4.3).
Todays âEnd golden hour in the morningâ is at 8:53.
I have a flowcard that checks if the âEnd golden hour in the morningâ is after 6:30 and it returns false (where it definitely should return true).
Is this a bug or am I interpreting things wrong?
I have checked it and this is indeed a bug. If you are in a hurry i will fix this today in the current app otherwise this will be fixed in the 2.0 release beginning next week.
Hi Marcel,
No, no need to hurry. Great it can be fixed in 2.0.
Have a great week-end
I have fixed it already Was very easy
Checked and confirmed! Thanks
I have published on test version 2.0 which is a completely new app written from the ground up. The app is backward compatible.
This version could contain bugs if you are running in production and you are depended on the app do not install this. Or you install it test it and re-install the production version.
thank you for your work, I just wonder, what was the need for full rewrite ? It was working fine
Some observations :
new version have bigger memory footprint - 10MB vs 16MB
the SunLight change trigger is triggered every 1 min - that was the case even in older version, not sure itâs intended, including negative values, maybe itâs serving as kind of MoonLight ?
what is the difference between Light Percentage TAG and Light Percentage from the trigger
(screenshot while itâs night - 9PM) -
not the difference, however when used as tag, itâs the same value,maybe just a glitch in the UI ?
I will test triggers during tomorrow, I will report if anything goes wrong.
Hi Marcel, just to inform you, while running the test version v1.6.0, I noticed this while running a flow test:
v1.4.4 stable:
FYI, just another odd issue, it is past 4 PM, sunset is just happening in over an hour, but the card says âit is not between sunrise and sunsetâ:
The trigger times seem spot on though:
No hurries and thanks again for all the effort.
Try to fix the errors. The reason that I did a rebuild is that the original code was messy. It was very hard to read and understand. The code was written in the first release of the Homey App and at that time everything was new and not well documented homey sdk. I adjusted the code every time but it became messier. So it was needed to start over
It maybe work from the outside but it was very hard to maintain.
New version:
v2.0.1 As far as I can see the issues are fixed now
Didnât test it yet, but I guess there is a little bug regarding the Circadian Brightness value, because 3 decimal digits are given instead of 2:
App version: 2.0.1
Here you find an updated version:
Fix confirmed!
App version: 2.0.2
Thx!!!
There seems to be a small calculation error of âMaximum Brightnessâ.
I have set the âMaximum Brightnessâ to 100, but in Insight only a maximum value of 0.99 (= 99) is displayed:
(For comparison, the values of the Circadian Lighting App.)
A similar problem with âNoon Warmth.â It is set to 20, but 0.21 (= 21) is the lowest value displayed in Insights:
Btw, because these features works great for me, I will deinstall the Circadian Lighting App und use the Sun Events App for this purpose.
Thanks for the great app!
Probably a rounding error. I will check this. Thanks for the trust in the app.
Updated app:
- Improved error handling
- Fixed display error of triggers
- Added moon information
- Added day length.
This morning the App v2.0.2 was paused for no reason: a3cd37d0-f6bd-4b9e-abb3-0004ea7ac1e4
Maybe you find out the reason or what happened.
But now I will update to v2.0.3
Apps get paused if they take up more than 80MB. You can check Insights if this was the case.
