The funny thing is, that the yellow animation in Energy does show power coming from the PV panels into the house:
So, perhaps it is a Homey Energy issue!
PS
Re added the Inverter again and reboot Homey.
Hello @Kim_Kokholm could you maybe just read the battery % level and present it like you do with kW?
Hi @Leopold_Ekdahl - the docs of the api, that is available to me, does not mention battery.
@Peter_Olausson maybe cooking - Peter, do you have a breakthrough?
Hello @Kim_Kokholm - this should have all you need
@Kim_Kokholm I am struggling over here ![]()
I have implemented a new capability “Battery SoC” but I can´t get the app to read the data from the Solis inverter.
I see that that the pdf that @Leopold_Ekdahl poset is a bit different than the version I have from SOlis - SolisCloud Platform API Document
V2.0.2
I have tried this:
batteryPercent Number N Battery SOC
But also tried this:
batteryCapacitySoc Number N Battery SOC
I thought I could see a pattern in your code Kim where you call to read data from the SOlis but I can´t really see how you do it ![]()
@Kim_Kokholm
I am also trying to read the SoC like your code with “measure_power” since Soc or more or less same type of value I think.
But I can´t understand how your code is created by reading the pdf´s that is in your folder DOcuments.
Can someone with batteries, share login with me. I do not own the device myself.
@Kim_Kokholm is iT possible when the Solis turns off set value to zero ?
Now on the devicce and energy tab it’s listed as a -
When unused a variable it won’t work
Already asked if here @Kim_Kokholm
I am doing a reset on start, the only value which is set to ‘-’ is “Capacity”, is this the one you are asking about or do you have other in mind?
When this occur, can you please share the devices capabilities: Device > Solar > …
I can share, what do you need?
Will guest login be enough?
Peter is currently in the making of the battery-device for Solis.
I think he will share an update when he is ready. We use his login for now, I will let you know, if we need more data.
We are aware that you want in the loop as soon as we are ready for test.
Can this be implemented also when implementing the battery control?
We have only started to read the data from the battery so that we then can have flow cards more or less as the Solis app is now that Kim hase made.
Progress for that is really good, Kim has provided me with great support and spirit.
I aim to have all the capabilites in line this weekend and then check with Kim how we procced.
Regarding sending data to the Solis is also what I really would like to do - like toggle charge slots and so on but that will be later on after the forst step.
Excelent to hear. One thing at the time. ![]()
Hi all - attention to those of you who is the happy own of the battery-solution from Solaris.
@Peter_Olausson is ready to reveal his great work for now. Test version is out.
Please check it out - you will find the new features in the “add new device” menu.
Please provide your feedback. Huge shoutout to Peter for this great work.
I am also very interested in this option. In order to adjust the power to your own consumption in the house. This is due to a negative rate.
For an automatic reset, use the “Set Output Power” option? See:
Everyone with a Solis in the Netherlands will be grateful to you. We have a Feed-in penalty or negative tariff. It is better to adjust production to self-consumption than to simply turn off the inverter. To avoid this.
Sorry if I am not using this thread correctly. I posted a question here but received no answer (yet).
My question is: does the Solis Cloud Inverter App report correctly in the Energy Tab in Homey Pro? I do see the numbers correctly in the Energy page, but miss the numbers in the top:
