[APP][Pro] SolarEdge + Growatt TCP modbus
Can you do updates? Have istaller account or ask installer for new soft. These are old ones.
Oh OK, need installer aid for that so will get that done and try again, thank you!
I have the latest test version. I don’t see a flow card which points to the gateway status.
it is a capability , no change trigger but you can use logic change trigger .grid status · biemond/solaredge.modbus@a266724 · GitHub
This was the issue, old software - after getting my installer to upgrade all the components it all started working, so many thanks for your advise @Alan_Raudmae!
Which logic change trigger do I have to use then? I used logic card now but don’t know which variable I have to use. The flow has to detect when the grid is off.
grid_status should work.
Hi @Edwin_Biemond
first of all thank you very much for your great app.
Do you have a chance to check the consumption values for the sh25t inverter?
created report => 9e9501f1-9842-4b7f-a77f-d3900f012d09
Cheers,
Sven
looks ok , did you update to your firmware also and use the test version of the app.
    "totaldcpower":   [5016,  2, 'UINT32', "Total DC power", 0],
    // # old firmware ( before october 2024): always positive battery power
    // # new firmware: positive if charging and negative if discharging
just pass on loadpower
totaldcpower 5738 0 Total DC power
battery_power 5271 0 battery_power
loadpower 316 0 Load power
exportpower 0 0 Export power
outputPower 103 0 Daily Output Energy pv + batt discharge
active_power_limit 250 -1 Nominal active power
Yes I use the current fimware and test version of the app
Maybe it is a modbus issue
The data is sometimes correct and sometimes not
can be online, they do some corrections or averages
Been using this awesome app now for a while and played around with the flows a bit, realising that actions for Huawei inverters are implemented only if you choose the template for 2 inverters and S-Dongle. I have a single inverter with S-Dongle and would love to get the possibility to control actions also for it. I tried adding a device with the dual inverter template but had no luck in connecting to my inverter.
Edit: Could add a device using template 2xinverter with S-Dongle, just took a while before it updated. The rest remains valid though.
I’m have using your app for a long time now, and i really like it. I’m using your Test version and for 2-3 updates ago, I see that some values is not updated even I have make changes on them (like BatterFirst). Is there a reason for this? If I need new values, I need to restart the app.
do you have a battery or smart meter? then you can use the battery 1 , normal huawei is very basic.
are you using the growatt 1 if so it can be this. Growatt SPH issues · Issue #126 · biemond/solaredge.modbus · GitHub ?
can you send me a report.
Yes it’s a Growatt (SPH3600). I have created a diag reprot: no.:
49bc0009-7d79-406f-98e1-e48978a6acbe
No way says Solaredge support.
Solaredge SE17k Inverter. Latest firmware.
Thats nonsens. You can also ask the company who placed and monitors to enable modbus. My inverter was 7 years old (with the display). You also have to enable it yoor self in the screen if you have a display.
also remembers it was gone and added back. there were some release notes about this. will check
Version Date - September 2022
no clue what is secure and unsecure wifi. maybe not using WEP.
