[APP][PRO] Smart Presence - Presence detection based on smartphones connected to your Wi-Fi
all my other guests and people in the house are on my 192.168.1..xxx netork and all is working well with the smart Presence app. But the Smart Pressence app is not detecting the presence of clients connected to the subnet 192.168.2.xxx. How can I do that with dummys you think ?
The subnet itself is not a problem. Smart Presence does not require Homey and the detected device to be in the same subnet/VLAN.
Homey only needs routed IP connectivity to the device.
In your case:
  • Homey: 192.168.1.x
  • phone/guest device: 192.168.2.x
Your UniFi gateway must therefore allow traffic from the Homey IP (or 192.168.1.0/24) towards 192.168.2.0/24 on the TCP port configured in Smart Presence.
One important detail: do not create a firewall REJECT rule for that port.
Smart Presence determines presence by trying to establish a TCP connection to the device. A reachable phone with a closed port normally responds with a TCP RST / connection refused, which tells the app that the IP host is alive.
So:
ALLOW:
Homey IP -> 192.168.2.0/24 -> configured Smart Presence TCP port
and let the phone itself reject the connection because the port is closed.
If the UniFi gateway DROPs the traffic, Smart Presence gets a timeout and considers the device unavailable.
If the UniFi gateway REJECTs the traffic, the gateway itself generates the rejection even when the phone is offline, which can make Smart Presence believe the device is always present.
Whether UniFi calls 192.168.2.x a “guest network” is irrelevant here. What matters is routing, firewall rules and whether client/network isolation is enabled.
Also make sure the phone has a predictable IP address, preferably via DHCP reservation, as Smart Presence tracks the configured IP address or you have DNS in right shape, you can also use hostnames.
But long story short… there is nothing special required in Smart Presence for another subnet — configure the UniFi routing/firewall correctly and it should work.
Many thanks Sharkys, I will try that solution :slight_smile: !!
And I can confirm its working !! many thanks :slight_smile:
Hello. How the app detect kids?
Version 0.9.17 (test) — Added duration-based arrival and departure Flow triggers for users, household members, kids and guests, including first-arrival and last-departure variants with selectable seconds or minutes.
Hi. I use this app when my kid comes home to disable the alarm. Since few days when i enable the alarm in the evening, after a few minutes is sets to disabled. I found out that the cause is happing in this app. If i check the log, it goes to “not present” to present all the time. Because of this it will set the alarm to disable. when i switch back to enable, after a few minutes the same accurs.
can you help with this?
That typically happens with phones that put their WiFi into sleep. This app needs the phone connected to your (in this case WiFi) IP network. If the phone disconnects, there’s nothing this app can do auto-magically to detect that phone.
And the phone might have had an update or a change of settings that causes it to behave differently.
That i found strange. I have 5 iPhones connected to the app. They all show the same logs. This problem as i mentioned before, occurs since a week. I use this app since June, and untill now i never had this problem.
There were no changes in the app at that time, which exclude problem with the app itself. Check iOS updates, router updates, ensure you uses hostnames or static IP assignments, check privacy settings on iPhone etc
These setting:
“‘Away Delay’: ‘90 seconds’,
‘Normal Mode Check Interval’: ‘15000 ms’,
‘Normal Mode Timeout’: ‘2 seconds’,
‘Stress Period’: ‘60 seconds’,
‘Stress Mode Check Interval’: ‘2500 ms’,
‘Stress Host Timeout’: ‘2 seconds’”
Where must I place these?
It’s in the device settings…
What is the source of the suggested settings where Away delay is set to 90 sec. I have seen it in other forums too and I can’t see it is appropriate.
The device default Away delay is 900 sec and some phones need even longer delay.
Under what circumstances can 90 sec be a good setting?!
The suggested settings are based on practical testing and experience with different devices. They are intended as a starting point, not as universally optimal values.
The 90-second Away Delay is primarily aimed at Android devices that remain consistently reachable over Wi-Fi, even when idle. In such cases, it allows significantly faster departure detection compared to the default 900 seconds.
However, I agree that 90 seconds can be too aggressive for phones that periodically stop responding to network requests due to power management, particularly iPhones.
There is no single ideal value:
  • 90 seconds: Faster departure detection, but requires reliable network responsiveness.
  • 200–300 seconds: A reasonable compromise for many devices.
  • 900 seconds: More conservative, minimizing false departures at the expense of slower detection.
Ultimately, the appropriate value depends on the phone, its power management, Wi-Fi behaviour and network environment. After all, that’s why it’s fully configurable, so you can set the best values that suits you and your environement.
Diagnostic ID : cea2607e-7073-41c5-92de-fe3f58b2a950
The app displays a “Timeout error” if a guest is switched from “Mark as Present” to “Mark as Absent” in manual mode.
Thanks for the diagnostic report. I reproduced a case where Smart Presence marked the guest as absent, but the manual control kept waiting for a departure Flow trigger and timed out. I’ve fixed that in the code. Once the next TEST version is available, could you mark the guest present, switch to absent, then switch back to present and confirm that all three changes work without a timeout?
Version 0.9.18 — Fixed a timeout when manually changing presence while Homey was processing a departure Flow trigger.
Thank you for the quick response!
Met vriendelijke groet,
Mr. Kevin Vullings
:red_question_mark:
translated from Dutch…
“This message and any attachments are intended exclusively for the intended recipient or his authorized representative. We ask you not to copy or provide this message or the attachment to persons for whom this information is not intended. If you have received this message but you are not the intended recipient or his authorized representative, we ask you to inform the sender about this and to destroy the original message and any attachments. Due to the electronic transmission of the message, no rights can be derived from the information.”
